best way to true position bolt pattern
Open your true position. Change it to Best Fit Bore Pattern (icons under heading).
Enter the Tolerance and select Datum Y as your Primary Datum.
Next, click the button where you would normally select your feature. Click Add Features. Select all of the cirlces/cylinders.
Next, under Best Fit, make sure Rotation and Translation boxes are checked. Click OK
Select MMC next to the Best Fit.
ok. will try that and hope it satisfies them. They want the holes to each other. which I assume is what this does. I originally just did a true position of each cylinder to "Y".
