[Ri...] Posted May 2, 2018 Share Posted May 2, 2018 This is a first, yay. We use two tier probe racks, the lower level is offset towards Y- axis to accommodate Vast XT Styli systems. Defining the Approach "Before and After" values is simple, and apparently only affects the tier in use. This means if you pick up a probe from the top of the rack, it can and will smash into the lower tier pots. Yay again. Is there a setting to define the Approach "Before and After" parameters for both tiers? Setting a large approach value to satisfy the upper offset tier is not an option, I can afford the loss of travel between the rack and the part location (Large part on a Contura). (Side note: Today, after running this job for several weeks, the software decides it will travel a different path than every time it ran for about 60 parts.) Link to comment Share on other sites More sharing options...
[Ow...] Posted May 2, 2018 Share Posted May 2, 2018 Rick, Do you mean an XXT probe rack? The approach and retract parameters are set for each individual pod on all of the Vast-XT two tier probe racks I've used . Link to comment Share on other sites More sharing options...
[Ri...] Posted May 2, 2018 Author Share Posted May 2, 2018 The Head is a Vast XT Gold. The upper rack sits back with enough clearance so the CMM can pick up probes from the bottom rack without a collision. However, Calypso seemed to take a short cut today fro the upper rack, down and towards Y- axis thru the lower rack pots. Link to comment Share on other sites More sharing options...
[Ow...] Posted May 2, 2018 Share Posted May 2, 2018 Wow, that sound's kind of buggish. Only thing I could think of is if the CMM outer clearance plane got flipped or modified to make the CMM it thinks it has to go in the direction it did?. Go to plan, navigation, and select the outer clearance plane to see if it doesn't cover the whole measurement and probe rack range. Link to comment Share on other sites More sharing options...
[Ri...] Posted May 3, 2018 Author Share Posted May 3, 2018 You would not believe some of the things this software has done since upgrading to v6.2.x This may be just another glitch. Im going to add a software request for a button to "Disable Glitchs". 🤣 🤠 Link to comment Share on other sites More sharing options...
[Ow...] Posted May 3, 2018 Share Posted May 3, 2018 Yep, I've read more than and few issues and that's why 6.2 continues to reside in my desk drawer. It's only fair to mention that, I know for a fact many other metrology software's and operation units also have glitches with upgrades. Even giant's like Microsofty has issues. Link to comment Share on other sites More sharing options...
