Got problem with measuring profile of surface
Technically, because you're datum reference frame is fully constrained, you could do surface profile one feature at a time. Your total surface profile result will be the worst result of the 4 features, 2 cylinders and 2 planes. You could mask the 4 results and use Max Result to report only the worst one.
Tom Oakes | 03-09-2018 12:49 PM |
Do you have curve?
There may be some arguments against it but, with that kind of tolerance, I wouldn't have a problem using curve, using U for spatial,a 3d-line between U and V for planar-rotation and Y origin, a symmetry between U and V for X origin and a bilateral tolerance on the curve characteristic.
In the industries I've worked in, Profile isn't used much and maybe for a lack of understanding, I believe the Profile result doesn't provide much info for manufacturing to adjust to without cad grapics.
Owen Long | 03-09-2018 02:15 PM |
