Got problem with measuring profile of surface
Hello everyone,
I am using CMM zeiss with software Calypso 5.8.
I got a part as in attach, but I do not know how to measure it by my CMM.
Would anyone please kindly help me with this matter.
Thank you guys in advance.
HoangTrong Van | 03-09-2018 03:57 AM |
Technically, because you're datum reference frame is fully constrained, you could do surface profile one feature at a time. Your total surface profile result will be the worst result of the 4 features, 2 cylinders and 2 planes. You could mask the 4 results and use Max Result to report only the worst one.
Tom Oakes | 03-09-2018 12:49 PM |
Do you have curve?
There may be some arguments against it but, with that kind of tolerance, I wouldn't have a problem using curve, using U for spatial,a 3d-line between U and V for planar-rotation and Y origin, a symmetry between U and V for X origin and a bilateral tolerance on the curve characteristic.
In the industries I've worked in, Profile isn't used much and maybe for a lack of understanding, I believe the Profile result doesn't provide much info for manufacturing to adjust to without cad grapics.
Owen Long | 03-09-2018 02:15 PM |
I use points and scanning, it depends on the feature(s) and customer requirements.
Some customers only trust points. Hundreds and hundreds of points.
Casey Sigler | 03-09-2018 02:36 PM |
