Formula or PCM Help
An if command can be used in the presettings of the TP in order to set the tolerance.
See attachment.
Use if to determine if L1 or L2 is smaller.
Use L1 or L2 - low limit of slot (0.250) to find bonus
Add base tolerance to bonus for total MMC Tolerance.
Add that tolerance to the TP.
Roberto Flores | 04-05-2018 05:47 AM |
https://qualityforum.zeiss.com/topic/21068-formula-or-pcm-help/#findComment-119974
And if you want to get deeper into the weeds, you can break down the "Total" tolerance down in to the base + the Bonus by adding a formula to the comment section.
This will keep the questions down on why the tolerance keeps changing and how exactly you got to that number.
Roberto Flores | 04-05-2018 11:42 AM |
https://qualityforum.zeiss.com/topic/21068-formula-or-pcm-help/#findComment-119980
