[ZE...] Posted April 9, 2018 Share Posted April 9, 2018 Please see attached. I measure two slots and I have to assigned bonus tolerance. Bonus comes from narrower slot. L1=slot1 L2=slot2 Dilipkumar Shah | 04-04-2018 05:31 PM | Link to comment Share on other sites More sharing options...
[ZE...] Posted April 9, 2018 Author Share Posted April 9, 2018 see attachment Dilipkumar Shah | 04-04-2018 05:59 PM |slot_bonus.pdf Link to comment Share on other sites More sharing options...
[ZE...] Posted April 9, 2018 Author Share Posted April 9, 2018 Try this, let me know if it works. Clarke Gilbert | 04-04-2018 07:08 PM |PCM_MMC.docx Link to comment Share on other sites More sharing options...
[ZE...] Posted April 9, 2018 Author Share Posted April 9, 2018 NEED TO USE IF COMMAND, IN PARAMETER OR ? Dilipkumar Shah | 04-04-2018 08:02 PM | Link to comment Share on other sites More sharing options...
[ZE...] Posted April 9, 2018 Author Share Posted April 9, 2018 Use this in the true position characteristic (see attached) Clarke Gilbert | 04-04-2018 09:24 PM | Link to comment Share on other sites More sharing options...
[ZE...] Posted April 9, 2018 Author Share Posted April 9, 2018 Right click in the highlighted area choose formula, enter the formula plus the given tolerance. Clarke Gilbert | 04-04-2018 09:27 PM | Link to comment Share on other sites More sharing options...
[ZE...] Posted April 9, 2018 Author Share Posted April 9, 2018 An if command can be used in the presettings of the TP in order to set the tolerance. See attachment. Use if to determine if L1 or L2 is smaller. Use L1 or L2 - low limit of slot (0.250) to find bonus Add base tolerance to bonus for total MMC Tolerance. Add that tolerance to the TP. Roberto Flores | 04-05-2018 05:47 AM | Link to comment Share on other sites More sharing options...
[ZE...] Posted April 9, 2018 Author Share Posted April 9, 2018 See attached. Andreas Binder | 04-05-2018 09:40 AM | Link to comment Share on other sites More sharing options...
[ZE...] Posted April 9, 2018 Author Share Posted April 9, 2018 And btw, i ASS-U-ME that by bonus you mean MMC and not LMC. If its LMC then the formulas need to be tweaked. Roberto Flores | 04-05-2018 11:19 AM | Link to comment Share on other sites More sharing options...
[ZE...] Posted April 9, 2018 Author Share Posted April 9, 2018 And if you want to get deeper into the weeds, you can break down the "Total" tolerance down in to the base + the Bonus by adding a formula to the comment section. This will keep the questions down on why the tolerance keeps changing and how exactly you got to that number. Roberto Flores | 04-05-2018 11:42 AM | Link to comment Share on other sites More sharing options...
[ZE...] Posted April 9, 2018 Author Share Posted April 9, 2018 Thanks, I will try this week. Dilipkumar Shah | 04-09-2018 03:08 PM | Link to comment Share on other sites More sharing options...
[ZE...] Posted April 13, 2018 Author Share Posted April 13, 2018 Damn Roberto, that's some nice work there. Kai KendallKKendall | 13.04.2018 00:09 | Link to comment Share on other sites More sharing options...
[ZE...] Posted April 13, 2018 Author Share Posted April 13, 2018 TY Roberto Flores | 13.04.2018 07:24 | Link to comment Share on other sites More sharing options...
