Simulation with RDS and VAST XXT Sensor
I have noticed when using the “stylus system creator” and “simulation” on machine with a RDS probe head and VAST XXT sensor, the stylus is not contact with the feature I am trying to measure. Do anyone know why this is happening? Attached is a screenshot of the values I entered for the “Stylus System” tab in the CMM configuration on my offline seat. I received these values from Zeiss many years ago.
https://qualityforum.zeiss.com/topic/21078-simulation-with-rds-and-vast-xxt-sensor/
Nope.. Vast XXT. I had the same issue with simulation not contacting the model. Zeiss Tech support adjusted these. On our off line seat there are 2 tabs on the bottom of the Extras>Settings>CMM>Stylus system
The contura tab has
Xs=0.0
Ys=60.0
Zs=192.900
On the simulation tab I have:
Xs= 0.0
Ys= 55.0
Zs= 135.00
Vast XXT RDS
On the contura tab mine is
Xs 0.000000
Ys 60.000000
Zs 191.700000
While the simulation tab
Xs 0.000000
Ys 0.000000
Zs 0.000000
I had to get these numbers from Zeiss as well. I just had this problem. Then we had to import the probe after reconnecting to the simulation tab.
The 0,55.00,135.00, xs,-ys,-zs settings are from the old RST days. A trigger head Zeiss sells for the RDS head. 0,65,192.00, xs, -ys,-zs values are more typical of XXT. I have found different versions and different SP's, especially those involving major changes to the Stylus System Creator can require "tweaks" to the initial Stylus System fields but more then likely it's "tweaks" to the qualification data for the individual styli position of a single styli. I have used "Plan/Travel to nominal position" for that. There are a couple things you may want to do first, like set your styli radius to zero. When you travel to your nominal point, the styli should be at ball center.
