[De...] Posted April 10, 2018 Share Posted April 10, 2018 Is there a mechanism to only print a physical report if the part is out of tolerance in Calypso? We are currently using custom reporting and not PiWeb Link to comment Share on other sites More sharing options...
[Me...] Posted April 10, 2018 Share Posted April 10, 2018 I'm not sure if this is the correct spot or not, as I've never actually used it, but I think it is probably where you want to look. If you go into Resources>Define Printout, you can arrange how it reports characteristics (I.E on the Compact/Custom Printout tabs), change the characteristic reporting to only ones triggered by the warning limit. Link to comment Share on other sites More sharing options...
[Da...] Posted April 10, 2018 Share Posted April 10, 2018 First go to “Resources” pull-down menu and choose “Characteristic Setting Editor”. Begin with the drop-down arrow in the upper left hand corner and look for “Printout”. Choose “Warning Limit in %”. Click on the radio button under “Accept for:” called “Measurement Plan”. In the “Set To” drop down enter 100. Next go to the “Resources” pull-down menu and choose “Define Printout”. Click on the tab called “Custom Printout”. To the right of “Characteristics” click on the drop-down arrow that says “All” and choose “From Warning Limit”. Warning Limit Image 01.pngFetching info... Warning Limit Image 02.pngFetching info... Define Printout.pngFetching info... Link to comment Share on other sites More sharing options...
