how can i global edit this...
does anyone know how I can global edit this vector direction reference?
I must change this to Z in order to get the correct radius nominal.
i have 300+ points to modify so you could see how this could get tedious. I don't believe there is a way in the measurement plan editor, but if anyone has any other ideas it is appreciated...
Thanks,
Joe
Joseph Giacona | 03-22-2018 08:39 PM |
https://qualityforum.zeiss.com/topic/21162-how-can-i-global-edit-this/
OK... ended up downloading a macro software, "TinyTask."
this just saved my fingers!
I recorded the button clicks and pinned it to the f8 button. Voila!
just turned a 15 minute task to a 2 minute task.
I can see a lot of uses for this macro software, thought I would share it. not sure how this compares to the calypso macros...
Joseph Giacona | 03-26-2018 05:13 PM |
Might not be as quick as the macro but, you could use the measurement plan editor to change multiple IJK at the same time.
Open up the editor, go to geometry nominal data and select the dimensions you want to change. If you have 300 of them you can press the ctrl button to select them all to desired setting.
Owen Long | 03-26-2018 05:53 PM |
