[Ro...] Posted November 11, 2024 Share Posted November 11, 2024 Hi guys, hoping I'm asking in the right place as this is my first post. I think its a relatively simple question. I recently took over CMM operation from our old guy, who on his reports always had angles reported as non degree numbers, eg: 80° is currently being reported as 1.4035 instead of 80°. When I open the feature itself, it shows as 80°±2° which is correct, but it just will not report that way no matter what I try. Please someone help! Link to comment Share on other sites More sharing options...
[Du...] Posted November 11, 2024 Share Posted November 11, 2024 I think this should solve your problem, try it out and let me know if it works for you, go under settings - environment, then there should be a language tab with the different types of angles Link to comment Share on other sites More sharing options...
[Ro...] Posted November 11, 2024 Author Share Posted November 11, 2024 Please sign in to view this quote. Thanks for the reply! I actually figured it out in a different area ( Measurement Plan Editor Features > Angle Units- Set to degrees) but I don't see an Environment setting in the CMM settings. Could you walk me through that navigation? I should have noted, we are still running Calypso 2016. Link to comment Share on other sites More sharing options...
[Du...] Posted November 11, 2024 Share Posted November 11, 2024 I Completely forgot about that, that would work just as well, i think it would only be for that program though, the way I did should change that to the default method. I attached a video of how to get there Desktop 2024.11.11 - 16.13.16.04.mp4 Link to comment Share on other sites More sharing options...
[Ro...] Posted November 12, 2024 Author Share Posted November 12, 2024 Please sign in to view this quote. Fantastic, that worked for me. Thanks so much! Link to comment Share on other sites More sharing options...
