[Da...] Posted November 19, 2024 Share Posted November 19, 2024 Zdravím všechny, Mám dotaz, zda je možné vytvořit rovinu a definovat rovinnost z více ( příklad 8 ) povrchových bodů . díky za pomoc Link to comment Share on other sites More sharing options...
[Na...] Posted November 21, 2024 Share Posted November 21, 2024 Hello Daniel, please translate your posts to English (or German 🙂 ) in the future, so it's easy to understand for everyone. You can select the points like in your screenshot -> right mouse button on a point -> select all points of element -> (red crosses will appear on the points) -> construct -> plane -> fitting plane. Measuring principle is "referenced construction" in this case. The resulting plane can be checked for planarity. Nanno Link to comment Share on other sites More sharing options...
[Da...] Posted November 25, 2024 Author Share Posted November 25, 2024 Hello, Muehl, Thank you, it is perfect . Daniel Link to comment Share on other sites More sharing options...
