[Ri...] Posted November 19, 2024 Share Posted November 19, 2024 I have a Cylinder in the Y axis. It uses two circle paths in the strategy. it has a depth of .7100". The first circle path starts at .0710". The second circle path start at .6390". The second circle path is the minimum depth I want to scan in this cylinder, the remainder is a larger tolerance. I know how to calculate the depth from the Cylinder geometry, it's how I set the minimum value (second circle path). I want to report the depth of the "second circle path". How do I extract this value with PCM?? Link to comment Share on other sites More sharing options...
[Ri...] Posted November 19, 2024 Author Share Posted November 19, 2024 And this should have been in the Calypso section...😁 Link to comment Share on other sites More sharing options...
[Ma...] Posted November 19, 2024 Share Posted November 19, 2024 Without PCM you can just create a circle using Recall Feature Points of the second circle. As long as the circle is relative to the appropriate alignment, you can just report the actual Y value for depth. You can also use result element and formula to make adjustments to the actual Y value to represent the depth value you want, if necessary. Link to comment Share on other sites More sharing options...
[Ri...] Posted November 19, 2024 Author Share Posted November 19, 2024 (edited) Please sign in to view this quote. Thank you, that did the trick! Sometimes I miss the obvious. Edited November 19, 2024 Link to comment Share on other sites More sharing options...
