[Uw...] Posted December 19, 2024 Share Posted December 19, 2024 Hallo Messtechniker, möchte gern eure Meinung zu folgender Zeichnungsangabe (siehe Skizze) haben: Koax.Ø0,1 A (BB) SL Ich würde folgendermaßen vorgehen: Fläche A scannen und als äußeres Tangentialelement auswerten; An den 6 Bohrungen Ø20 H7 je einen Zylinder messen; Aus den 6 Zylinderachsen über Rückruf eine Mittelachse bilden; Diese Achse mit der Ebene A schneiden. Würdet ihr das Koordinatensystem auch so aufbauen? Vielen Dank und schöne Weihnachten! Uwe Skizze.pdf Link to comment Share on other sites More sharing options...
[Ma...] Posted December 19, 2024 Share Posted December 19, 2024 That is new ISO also - unfortunately i don't have that book at home. That circle for profile callout is telling in which direction you should evaluate. CZ will be common zone and SZ will be each face separately. B-B will surelly mean pattern, but i am not sure now what is [SL]. Link to comment Share on other sites More sharing options...
[na...] Posted December 20, 2024 Share Posted December 20, 2024 Please sign in to view this quote. I would create a Best Fit Bore Pattern of the 6 20 mm diameter bores to datum A. This will create a new Best Fit datum system, which I would use as datum system for coaxiality/concentricity. For profile's datum system, [SL] Straight Line is needed. In other words, you need 4 degrees of freedom locked from B-B pattern (2 rotation and 2 translation), but not the 5th rotation. Where exactly on the part are features tolerated with profile? Link to comment Share on other sites More sharing options...
[Uw...] Posted December 21, 2024 Author Share Posted December 21, 2024 Hello, Thank you for your answers. If I place the part on the measuring plate so that reference A is at the top, A already restricts 2 rotational degrees of freedom and one translational degree of freedom (in this case Z). If I then enter a BestFit of the cylinder axes as the zero point (in this case in X and Y), what degree of freedom remains? I probably don't have enough experience with the standard yet? Link to comment Share on other sites More sharing options...
[na...] Posted January 7, 2025 Share Posted January 7, 2025 Please sign in to view this quote. There are 6 DoF, 3 rotations and 3 translations. With Best Fit Bore Pattern of the 6 bores to datum A you will get a new calculated Best fit with all 6 DoF locked. In order to evaluate Coax.Ø0,1 there is no difference in datum system |A|(B-B) [SL]| and |A|(B-B)| With |A|(B-B)| there are 6 DoF locked and with |A|(B-B) [SL]| the last rotational DoF is released, which has no impact when evaluating coaxiality. I hope what I wrote makes some sense. Link to comment Share on other sites More sharing options...
