[Ra...] Posted January 7, 2025 Share Posted January 7, 2025 Is there a way to run a program continuously in a loop? We are expecting some visitors next week, and management has asked if it's possible to set my machine to run the program nonstop. I' have calypso 2022. Thank you, Link to comment https://qualityforum.zeiss.com/topic/21678-is-there-a-way-to-run-a-program-continuously-in-a-loop/ Share on other sites More sharing options...
[Ma...] Posted January 8, 2025 Share Posted January 8, 2025 (edited) That was mentioned somewhere on forum. Just right click on characteristic page to clear area ( having selected none of characteristics ) - there is loop. Another approach i cycle in Autorun mode ( but that will come with protocols and evaluations ) Found link - Edited January 8, 2025 Link to comment https://qualityforum.zeiss.com/topic/21678-is-there-a-way-to-run-a-program-continuously-in-a-loop/#findComment-123518 Share on other sites More sharing options...
[An...] Posted June 10, 2025 Share Posted June 10, 2025 What Martin said. Here is an image to help guide the process. 1 Link to comment https://qualityforum.zeiss.com/topic/21678-is-there-a-way-to-run-a-program-continuously-in-a-loop/#findComment-133533 Share on other sites More sharing options...
[DW...] Posted June 26, 2025 Share Posted June 26, 2025 Please sign in to view this quote. Looping is also great if you are running a large set of parts, and don't want to have to constantly go through the 'RUN' screens. Just put a programmable stop in the CNC End Park Position, swap out the part, and hit enter on the controller and you're back to measuring. 1 Link to comment https://qualityforum.zeiss.com/topic/21678-is-there-a-way-to-run-a-program-continuously-in-a-loop/#findComment-134401 Share on other sites More sharing options...
[Lu...] Posted June 26, 2025 Share Posted June 26, 2025 Please sign in to view this quote. Does it save a report for each time it loops? Link to comment https://qualityforum.zeiss.com/topic/21678-is-there-a-way-to-run-a-program-continuously-in-a-loop/#findComment-134403 Share on other sites More sharing options...
[Ri...] Posted June 26, 2025 Share Posted June 26, 2025 Please sign in to view this username. Yes 1 Link to comment https://qualityforum.zeiss.com/topic/21678-is-there-a-way-to-run-a-program-continuously-in-a-loop/#findComment-134405 Share on other sites More sharing options...
[To...] Posted June 27, 2025 Share Posted June 27, 2025 (edited) Please sign in to view this quote. If you press F8 on the joystick controller box, it will open the run window. Then, click the Lower Return to start the run. That eliminates in any interaction with the computer. Edited June 27, 2025 1 1 Link to comment https://qualityforum.zeiss.com/topic/21678-is-there-a-way-to-run-a-program-continuously-in-a-loop/#findComment-134417 Share on other sites More sharing options...
[DW...] Posted June 27, 2025 Share Posted June 27, 2025 Please sign in to view this quote. Please sign in to view this username. This is a very helpful tidbit of information. Thank you! 1 Link to comment https://qualityforum.zeiss.com/topic/21678-is-there-a-way-to-run-a-program-continuously-in-a-loop/#findComment-134419 Share on other sites More sharing options...
