[Lo...] Posted January 8 Share Posted January 8 (edited) Hello, I am working on a part that I have had a proven program for that has worked great in the past. This time when I went to use the program all of my clearance planes have changed Z+ to Y- and so on. Why does this happen and how to do I change it back. I have been trying to manually change it in the clearance plane group and in the individual feature settings but the changes don't stay. I appreciate any assistance. Thank you. Lou Edited January 8 Link to comment Share on other sites More sharing options...
[Ma...] Posted January 8 Share Posted January 8 If you click on "Cancel" then those changes on CP won't be applied. I would manually recheck alignment to let machine know how is part laying in workspace ( i still don't know how it's labeled in english for manual alignment ). Link to comment Share on other sites More sharing options...
[Lo...] Posted January 8 Author Share Posted January 8 Please sign in to view this quote. Thanks. These changes are automatically done once I open the program. And I have done a manual alignment several times and it doesn't change the CP. Link to comment Share on other sites More sharing options...
[DW...] Posted January 8 Share Posted January 8 Can you screenshot your base alignment or explain how you are clocking rotation on this part? Also, go to Plan>Navigation>Block edges.. and screenshot that too. Link to comment Share on other sites More sharing options...
[Ke...] Posted January 8 Share Posted January 8 To clarify: Does the screen that you posted pop up whenever you open a program?? It should only open after creating a new base alignment, of modifying an old one. If it is a proven program, then there shouldn't be any need to modify it... curious. When it asks "Check definition of Clearance Plane - Update Clearance Plane Settings...", I always select "NO" and verify my Clearance Planes in the Feature Settings Editor. Link to comment Share on other sites More sharing options...
[Ma...] Posted January 8 Share Posted January 8 Always select No when prompted with this prompt. There is no undo. However, you can change in mass on the Measurement Plan Editor Feature page. Travel/ Clearance Plane. Link to comment Share on other sites More sharing options...
