Data export with CSV file: facet indexing
Dear all,
in old versions of GOM-Aramis (i.e. Aramis V 6.3.0, GOM mbH, Braunschwieg, Germany) the set of facets was indexed using rows and columns (facets were part of a "Caretesian plane" and therefore eachone had a row and column index). Would it be possible to index the facets generated by Zeiss Inspect Correlate 2023 in the same way?
Now it seems to me that the facet index is represented by a single progressive number.
Thanks in advance
https://qualityforum.zeiss.com/topic/21700-data-export-with-csv-file-facet-indexing/
Thanks Mohamed for the reply.
Attached is an example file exported from the old version of the software.
The "Cartesian" indexing was particularly useful to me for rapid local identification and for post-processing of the data.
If anyone could tell me if it is possible to set this type of export format I would be grateful.
