[An...] Posted February 3, 2025 Share Posted February 3, 2025 Is it possible to turn off air scanning for a selected feature? Thanks in advance! Link to comment Share on other sites More sharing options...
[Mi...] Posted February 3, 2025 Share Posted February 3, 2025 It is technically possible to disable it, for the entire program, not a specific feature. It's such a bad idea that I'm not going to say how, but it's buried, for good reason. The Scanning Optimization protects you from bad results. Your better course of action will likely be to improve the program so it can measure the feature in question without risking air scanning. Slowing down, using a more correct nominals, using Measurement Ref/secondary alignments/ or formula's to help the CMM find the features in question. Link to comment Share on other sites More sharing options...
[Ha...] Posted February 3, 2025 Share Posted February 3, 2025 Disabling the scanning optimization will produce incorrect results. I would recommend using a measurement reference (Own Geometry) as one possible option if the features in question are significantly displaced. https://portal.zeiss.com/knowledge-base?id=1262073 Link to comment Share on other sites More sharing options...
[An...] Posted February 5, 2025 Author Share Posted February 5, 2025 Thanks for the answers, I knew it was a bad idea but was curious what the difference would be since the stylus was making contact with the part the entire time. I will just trust Zeiss on this Link to comment Share on other sites More sharing options...
