Move fixtures independently
Hello,
I have a project with two CADs imported as fixtures, can I move one fixture and then move the other fixture independently?
I found a way to do this, but it is a bit complicated. I import fixtures as components and create a measuring configuration then I move them and back them to fixture tree.
Hi eduardo ,
The only other option is a single element transformation in this special case.
To be honest it would be better handling this in your cad software , for example if in NX to create appropriate assembly constraints between the two items and rexport.such that both fixtures are in same co ordinate system.
Hope that that helps
In CAD software it is way more easy, but I can't use CAD Software on ScanBox PC unfortunatelly. I'll keep using the workaround
Thank you!
