Contura Key
On my Contura G2 there is a key next to the emergency shut off button. There is 3 options for the key position, Man, O, and Auto. It is set to Auto. What is "O"? Does the machine run slower if the key is in the "O" position?
It should be for limiting speed - auto should be max of machine, man should be limited for 80 i think and 0 should be stop - no movement.
Also that info should be visible whenever you want to start program ( for ex. Vmax = 80 ).
