[Ja...] Posted February 12, 2025 Share Posted February 12, 2025 Hello everyone, I have a quick question about a composite positional tolerance. I'm wondering about the second tier of this, where the callout is to only the A datum. On this part, the A datum is a freeform surface, which I have created a work plane in order to use this surface in my datum structures. My question is this: when I am setting up the best fit of bore pattern, do I check mark the boxes titled "Rotation" and "Translation"? I'm under the impression that I do for this particular datum structure, as the pattern is free to rotate and translate when only called to A. I have attached an image of the strategy and callout in question. Thank you in advance! 367 COMPOSITE TOLERANCE.docx Link to comment Share on other sites More sharing options...
[To...] Posted February 12, 2025 Share Posted February 12, 2025 (edited) Please sign in to view this quote. Not trying to bust your chops and I see you're new to the forum but there is a forum for Calypso General Discussions. Edited February 12, 2025 Link to comment Share on other sites More sharing options...
[Ja...] Posted February 12, 2025 Author Share Posted February 12, 2025 Please sign in to view this quote. I have reposted there, thank you! Link to comment Share on other sites More sharing options...
[Ca...] Posted February 12, 2025 Share Posted February 12, 2025 (edited) Make two positional callouts. One for the top with rotation and translation not check. The second one for the bottom with both rotation and translation checked. Edited February 12, 2025 Link to comment Share on other sites More sharing options...
