Generate Excel Calypso report.
 The initialization file is located here - "C:\Users\Public\Documents\Zeiss\CALYPSO\data\excel_report\ReportINI.xls"
Since you did not know where this file was located, I am assuming you wouldn't have modified it. Do you use PCM?
I attached a known working copy of ReportINI.xls if you want to try replacing yours in the mean time.
ReportINI.xls
I have that problem once in a while. I think it started when IT made some changes to our network security. Simply opening a blank excel file takes longer now and every once in a while my excel report doesn't generate and I get that message. Sometimes it locks everything up and I have to restart the computer. It usually happens on the first part ran in the morning and then it's fine after that but once in a while it happens randomly in the middle of the day. I would like to know if there is a way to manually execute the ini file in the morning before running a program to make sure it will work.
Hello all,
Please review this knowledge base article. There is an attached replacement for the Excel generating exe we use that should hopefully give you a more useful error. I have fought this "error 100" many, many times and unfortunately it just isn't very diagnostic.
https://portal.zeiss.com/knowledge-base?id=1263814
I hope this is helpful.
Hi all,
My company still use Calypso 2014 and we have 1 PC where the excel report can't be generated. We are getting this error100 message all the time. I have tried everything from this forum and it is still not working. We do not have the PCM. Any suggestions please ?
