[Ma...] Posted February 17 Share Posted February 17 My software is no longer generating Excel, could someone help me? I have tried every possible way, but I can't find the path to Excel reporting. Link to comment Share on other sites More sharing options...
[DW...] Posted February 17 Share Posted February 17 Please sign in to view this quote. Please sign in to view this username. The initialization file is located here - "C:\Users\Public\Documents\Zeiss\CALYPSO\data\excel_report\ReportINI.xls" Since you did not know where this file was located, I am assuming you wouldn't have modified it. Do you use PCM? I attached a known working copy of ReportINI.xls if you want to try replacing yours in the mean time. ReportINI.xls Link to comment Share on other sites More sharing options...
[Ro...] Posted February 18 Share Posted February 18 When that happens to me, that means Excel itself has crashed. Killing Excel in task manager, or a straight up PC restart is what has worked for me. Link to comment Share on other sites More sharing options...
[Ma...] Posted February 18 Author Share Posted February 18 Please sign in to view this quote. Hello Roberto, Yes, I have already tried this alternative and it did not work. Thank you. Link to comment Share on other sites More sharing options...
[Ma...] Posted February 18 Author Share Posted February 18 Please sign in to view this quote. Yes, the path here8 is the same, I downloaded your file and the error still persists. Could it be that it is a variable or some macro that is not active? Link to comment Share on other sites More sharing options...
[Ja...] Posted February 19 Share Posted February 19 I have that problem once in a while. I think it started when IT made some changes to our network security. Simply opening a blank excel file takes longer now and every once in a while my excel report doesn't generate and I get that message. Sometimes it locks everything up and I have to restart the computer. It usually happens on the first part ran in the morning and then it's fine after that but once in a while it happens randomly in the middle of the day. I would like to know if there is a way to manually execute the ini file in the morning before running a program to make sure it will work. Link to comment Share on other sites More sharing options...
[Ky...] Posted February 20 Share Posted February 20 Hello all, Please review this knowledge base article. There is an attached replacement for the Excel generating exe we use that should hopefully give you a more useful error. I have fought this "error 100" many, many times and unfortunately it just isn't very diagnostic. https://portal.zeiss.com/knowledge-base?id=1263814 I hope this is helpful. Link to comment Share on other sites More sharing options...
[Da...] Posted February 26 Share Posted February 26 Hi all, My company still use Calypso 2014 and we have 1 PC where the excel report can't be generated. We are getting this error100 message all the time. I have tried everything from this forum and it is still not working. We do not have the PCM. Any suggestions please ? Link to comment Share on other sites More sharing options...
[Ma...] Posted Wednesday at 12:56 PM Author Share Posted Wednesday at 12:56 PM Please sign in to view this quote. Bom dia Kyle, infelizmente esta pagina não esta mais disponível, teria outro link? Link to comment Share on other sites More sharing options...
