Evaluation of a sphere
Hi all,
I've a question regarding how to interpretate the evaluation of a sphere that is a datum.
Do you think use as datum 3D-line from A1 to A2 is correct?
How can i evaluate it to use as datum?
I don't have curve.
What about to use only the A2 point? The refence datums are A and B.
I try to use the 3D line as datum A and cylinder as datum B or A2 point as A and circle as B.
Do you have other suggestions?
I am not sure how your callouts looks like, but i have an idea.
Before getting circle A2 you should establish main axis ( some cylinder to get close to axis A2-A1 )
Now you can get circle A2. Then you can make point A1 with calculation: simple trigonometry - R=36,06 / a=25,5 / b = √(R²-a²) = 25,4965 ( it's almost 45° )
So your A1 would be further from A2 by 25,4965.
It's not common to have datums like this, but here i think that datum A is indeed 3d line from A1 to A2.
Then your datum B should be circle to you be able to rotate alignment to 22,36°
The distance between A1 & A2 is too short for a stable datum. I would measure the sphere using lots of points. That gives you A1. Then create two more theoretical points. One at 51 +X from center and one 51 -X (A2) from center. Then construct a 3d line from those three points.
