[Ca...] Posted Wednesday at 07:00 PM Share Posted Wednesday at 07:00 PM We received a test plan from a customer. It contains a large number of plots in landscape format in the PIWEB report. Does anyone know how I can remove these from the test plan? The numerical values are perfectly sufficient for us. Link to comment Share on other sites More sharing options...
[Lu...] Posted Wednesday at 07:08 PM Share Posted Wednesday at 07:08 PM Hi Carsten, You most likely can turn off "Exchange row template" to remove the plots. If that doesn't do it, you may have to edit or change the PiWeb reporting template. Link to comment Share on other sites More sharing options...
[Ma...] Posted Wednesday at 07:46 PM Share Posted Wednesday at 07:46 PM Either remove plots from PiWeb template ( i have one with and one without them ) If those plots are CAD views, then exclude those CAD views from selection for run. I don't think that unchecking show and print plot from characteristics will apply for PiWeb - i believe it's only for older protocols - but it may stop them to pop up. Link to comment Share on other sites More sharing options...
[Ky...] Posted Wednesday at 09:46 PM Share Posted Wednesday at 09:46 PM The end of this document covers how to turn on the plots, but doing the opposite should stop them from showing up in PiWeb (unless they added the plot protocol, in which case, you can delete that from the report features list). https://portal.zeiss.com/knowledge-base?id=443694 Link to comment Share on other sites More sharing options...
[Ca...] Posted yesterday at 05:40 PM Author Share Posted yesterday at 05:40 PM Leider kann ich diesen Link nicht öffnen. Können Sie mit sagen warum nicht? Link to comment Share on other sites More sharing options...
[An...] Posted yesterday at 05:46 PM Share Posted yesterday at 05:46 PM That Knowledge Base is US only. Kyle is referring to this: If the "Exchange Row Template" box is marked, unmark it. Link to comment Share on other sites More sharing options...
[Ky...] Posted 1 hour ago Share Posted 1 hour ago I'm sorry, Carsten, I didn't realize you weren't in North America. For right now, at least, the knowledge base I believe is only accessible from North America. I have heard of talks to have it available outside of that region, but I have no idea where those talks are right now I am afraid.... Link to comment Share on other sites More sharing options...
