Remove Plot from report
We received a test plan from a customer.
It contains a large number of plots in landscape format in the PIWEB report.
Does anyone know how I can remove these from the test plan? The numerical values are perfectly sufficient for us.
Hi Carsten,
You most likely can turn off "Exchange row template" to remove the plots. If that doesn't do it, you may have to edit or change the PiWeb reporting template.
Either remove plots from PiWeb template ( i have one with and one without them )
If those plots are CAD views, then exclude those CAD views from selection for run.
I don't think that unchecking show and print plot from characteristics will apply for PiWeb - i believe it's only for older protocols - but it may stop them to pop up.
Leider kann ich diesen Link nicht öffnen. Können Sie mit sagen warum nicht?
That Knowledge Base is US only. Kyle is referring to this:
If the "Exchange Row Template" box is marked, unmark it.
I'm sorry, Carsten, I didn't realize you weren't in North America. For right now, at least, the knowledge base I believe is only accessible from North America. I have heard of talks to have it available outside of that region, but I have no idea where those talks are right now I am afraid....
