[Jo...] Posted April 7 Share Posted April 7 Good morning all, I am looking to see if it is possible to create a line based on the minimum distance between two curves using the "Curve Distance" Characteristic. See the attached image. Have a minimum distance line created in the CAD window. I want to use the line created between the two points to do further calculations. Is this possible? I could not figure out a way to create two points in the same location to simulate how the calculation works in the characteristics. Appreciate the help! Link to comment Share on other sites More sharing options...
[Cl...] Posted April 7 Share Posted April 7 (edited) You should be able to construct a 3d line by using the two points created by a Minimum or Maximum coordinate. pull each curve into a Min & Max coordinate. Using the nominal feature option. Edited April 7 Link to comment Share on other sites More sharing options...
[Jo...] Posted April 7 Author Share Posted April 7 Please sign in to view this quote. Hey Clarke, I did try that, but it was just a min/max relative to the coordinate system and not relative to the relationship between the two curves. Link to comment Share on other sites More sharing options...
[Cl...] Posted April 8 Share Posted April 8 What about opening two-point features and recalling individual opposing curve points into each one from each of the two curves? Then recall those constructed points into a 3d line? Link to comment Share on other sites More sharing options...
[Jo...] Posted April 8 Author Share Posted April 8 Morning Clarke, I understand what you mean, but the software doesn't provide any insight into the points being used for this curve distance evaluation. I tried a formula to see what I could extract from the curve distance characteristic, but it only gives me the option to select XYZ and actual. I am starting to believe it's not possible. Link to comment Share on other sites More sharing options...
[Cl...] Posted April 8 Share Posted April 8 Are you trying to construct a line parallel or perpendicular to the curves? Link to comment Share on other sites More sharing options...
[Cl...] Posted April 8 Share Posted April 8 Never mind I see. Link to comment Share on other sites More sharing options...
[Ha...] Posted April 11 Share Posted April 11 Could you try recalling a specific curve point, e.g. point 150, check the box for Curve result points (Filtered,...), then recall the two points into a 3D line? Link to comment Share on other sites More sharing options...
[Jo...] Posted April 14 Author Share Posted April 14 Please sign in to view this quote. I thought about this as well. The only problem is that the evaluation doesn't give me the point # to try this. Link to comment Share on other sites More sharing options...
[Lu...] Posted April 22 Share Posted April 22 Have you found a solution yet? Link to comment Share on other sites More sharing options...
[Ma...] Posted April 22 Share Posted April 22 I have to admit, that i did not fully gained both points - perhaps wrong curves - but i've made two copies of distance of curve, where i swapped features ( curve_distance_1: 1c / 2c || curve_distance_2: 2c / 1c ) and set both on same ( min/min || max/max ) - then you can use formula to obtain X,Y,Z for a point ( using curve_distance_1 and 2 to get 3d line ) I don't know what author needs. Link to comment Share on other sites More sharing options...
