measure percentage of concavity or hollow in a crowned lead
There is a characteristic called "Helix Hollow" (specifically it is f_hoß, or at least I think that's what it's saying). I actually think its been there at least since 2018 (since I started using Gear Pro regularly), though I'm not 100% sure it is what you are looking for. Hopefully Roman sees this tomorrow and can weigh in a bit. I understand the mor normal characteristics, but some of these specialized things (like twist and hollow) I'm not nearly as familiar with.
  • 4 weeks later...
It's not for gears, but in PCM there are those commands - perhaps you can find them helpfull in other areas
numberOfPointDistanceExceed
Specifies the number of curve points with a deviation greater than the
reference value. The syntax is:
numberOfPointDistanceExceed("CurveFormName", reference value)
The function returns the number of points.
Example:
numberOfPointDistanceExceed ("CurveForm1", 0.025) counts the
number of curve points with a deviation > 0.0025 and returns the number.
numberOfPointDistanceLessThan
Specifies the number of curve points with a deviation smaller than the
numberOfPointDistanceLessThan("CurveFormName", reference
value)
Example:
numberOfPointDistanceLessThan ("CurveForm2", 0.001) counts the
number of curve points with a deviation < 0.001 and returns the number.
