[Cl...] Posted April 14, 2025 Share Posted April 14, 2025 I can't share any drawings. The callout is cumulative runout relative to Datum -A- which is a very shallow (.150" depth x Ø.52535" cylinder). The feature (a .200 Ø cylinder) is approximately 1.5" from -A-. I think it's because -A- isn't deep enough or close enough. My type-1 was 98% for this characteristic. Any ideas as to how I can improve repeatability? Link to comment https://qualityforum.zeiss.com/topic/23139-cumulative-runout/ Share on other sites More sharing options...
[Ky...] Posted April 14, 2025 Share Posted April 14, 2025 Not anything that conforms to the print. Unfortunately, that datum is way too shallow (for the diameter) to get a reasonable axis. Truth be told, I have a hard time believing that physically it is controlling that orientation when it spins. If I were in your place, I would probably request a change to the print so that a more reasonable datum is used. Without seeing the part, I can't say what, but like I said, it is highly unlikely that datum A by itself is controlling the orientation. Link to comment https://qualityforum.zeiss.com/topic/23139-cumulative-runout/#findComment-130281 Share on other sites More sharing options...
[Cl...] Posted April 14, 2025 Author Share Posted April 14, 2025 There is a secondary (Plane) datum parallel to -A-. Link to comment https://qualityforum.zeiss.com/topic/23139-cumulative-runout/#findComment-130287 Share on other sites More sharing options...
[Ky...] Posted April 14, 2025 Share Posted April 14, 2025 For the plane to matter (in the datum reference frame), the plane would have to be primary. You can try that (i.e. put in the plane as primary and the cylinder as secondary). If the callout is cylinder then plane, then that is probably the intended callout, even if they put it in wrong. Alternatively, you can measure the cylinder as a circle instead and then create a perpendicular from that circle to the plane. Link to comment https://qualityforum.zeiss.com/topic/23139-cumulative-runout/#findComment-130311 Share on other sites More sharing options...
[Cl...] Posted April 15, 2025 Author Share Posted April 15, 2025 👍 Link to comment https://qualityforum.zeiss.com/topic/23139-cumulative-runout/#findComment-130333 Share on other sites More sharing options...
[To...] Posted April 15, 2025 Share Posted April 15, 2025 (edited) cannot delete my post. Edited April 15, 2025 Link to comment https://qualityforum.zeiss.com/topic/23139-cumulative-runout/#findComment-130349 Share on other sites More sharing options...
[To...] Posted April 15, 2025 Share Posted April 15, 2025 (edited) Please sign in to view this quote. You can still use the cylinder, it will just origin the axis to the midpoint of the cylinder axis. But, I agree that a circle would probably be just as good. Edited April 15, 2025 Link to comment https://qualityforum.zeiss.com/topic/23139-cumulative-runout/#findComment-130351 Share on other sites More sharing options...
[Cl...] Posted April 16, 2025 Author Share Posted April 16, 2025 (edited) Using the plan/cylinder (A/B) the best I get on the type-1 GRR is 75%. Edited April 16, 2025 Link to comment https://qualityforum.zeiss.com/topic/23139-cumulative-runout/#findComment-130449 Share on other sites More sharing options...
[Ma...] Posted April 16, 2025 Share Posted April 16, 2025 From the description so far, it sounds like the two cylinders should be used as a compound datum. Then cumulative runout of each cylinder could be compared to that compound datum. Link to comment https://qualityforum.zeiss.com/topic/23139-cumulative-runout/#findComment-130457 Share on other sites More sharing options...
[Cl...] Posted April 16, 2025 Author Share Posted April 16, 2025 Datum -A- is a plane right next and parallel to -B-. Datum -B- is a cylinder Ø .52535 / .150 depth. The feature being evaluated for runout is also a cylinder Ø .20025 / .200 depth and is 1.5" from Datums A&B. Link to comment https://qualityforum.zeiss.com/topic/23139-cumulative-runout/#findComment-130459 Share on other sites More sharing options...
[To...] Posted April 16, 2025 Share Posted April 16, 2025 Please sign in to view this quote. How about plane/circle? Link to comment https://qualityforum.zeiss.com/topic/23139-cumulative-runout/#findComment-130461 Share on other sites More sharing options...
[Ow...] Posted April 16, 2025 Share Posted April 16, 2025 (edited) Plane/circle is going offer the best repeatability. If you are adamant about using a cylinder, be sure to use at least 3 equally spaced circle scanning paths, 5 wouldn't hurt. Two scanning circle paths will create projection error on a cylinder feature. Edited April 16, 2025 Link to comment https://qualityforum.zeiss.com/topic/23139-cumulative-runout/#findComment-130467 Share on other sites More sharing options...
[Ma...] Posted April 16, 2025 Share Posted April 16, 2025 Please sign in to view this quote. Understood, the problem is that -B- is too short to function as a planar datum. I am suggesting the planar be a 3d line constructed from -B- and the .20025 cylinder. I understand that this is not what is on the drawing, but doing it that way should greatly improve your GRR result. I can't comment on the functional datum structure of the part from the info provided, but the datum structure on the drawing is clearly not functional. Link to comment https://qualityforum.zeiss.com/topic/23139-cumulative-runout/#findComment-130477 Share on other sites More sharing options...
[Cl...] Posted April 16, 2025 Author Share Posted April 16, 2025 I agree. Thanks for the input, guys! I think my engineer is going to talk to the customer about this as an unreliable datum. Maybe talk them into changing it. Link to comment https://qualityforum.zeiss.com/topic/23139-cumulative-runout/#findComment-130503 Share on other sites More sharing options...
