[Do...] Posted April 15, 2025 Share Posted April 15, 2025 Just wanting to know what my options are for measuring distances when I do not have "caliper distance" in our version of CALYPSO. We are running an older version, and I am hoping that there is something that can be used other than "cartesian distances". Link to comment https://qualityforum.zeiss.com/topic/23147-caliper-distance-not-available/ Share on other sites More sharing options...
[To...] Posted April 15, 2025 Share Posted April 15, 2025 Curious as to why you don't want to use cartesian distance. Link to comment https://qualityforum.zeiss.com/topic/23147-caliper-distance-not-available/#findComment-130345 Share on other sites More sharing options...
[Do...] Posted April 15, 2025 Author Share Posted April 15, 2025 Please sign in to view this username. I have just heard that so many people prefer caliper distance over cartesian, so I thought I would ask the question since my version does not contain the caliper distance. I don't mind using the cartesian distance tool I just sometimes wonder about when to use the additional selections for the primary and secondary datum feature(s) and the parallel or perpendicular drop downs. Is there any literature or material out there on the proper way to use cartesian in this manner? Link to comment https://qualityforum.zeiss.com/topic/23147-caliper-distance-not-available/#findComment-130359 Share on other sites More sharing options...
[Ri...] Posted April 15, 2025 Share Posted April 15, 2025 Please sign in to view this quote. https://portal.zeiss.com/knowledge-base?id=528649 The knowledge base contains a lot of great information. Link to comment https://qualityforum.zeiss.com/topic/23147-caliper-distance-not-available/#findComment-130363 Share on other sites More sharing options...
[Do...] Posted April 15, 2025 Author Share Posted April 15, 2025 Please sign in to view this quote. Thanks Richard. I was unaware of this knowledge base site. Link to comment https://qualityforum.zeiss.com/topic/23147-caliper-distance-not-available/#findComment-130365 Share on other sites More sharing options...
[To...] Posted April 15, 2025 Share Posted April 15, 2025 Please sign in to view this quote. One thing that this leaves off is that if you don't specify the datums, in some cases, you get the 2d distance without the need to specify the projection plane. Link to comment https://qualityforum.zeiss.com/topic/23147-caliper-distance-not-available/#findComment-130369 Share on other sites More sharing options...
[To...] Posted April 15, 2025 Share Posted April 15, 2025 Please sign in to view this username. Yes, I have also seen the resistance to using cartesian. It's just one tool in the toolbox. The caliper tools certainly add some extra options, i.e. max to min, center to center, etc., which are great improvement to Calypso. Link to comment https://qualityforum.zeiss.com/topic/23147-caliper-distance-not-available/#findComment-130373 Share on other sites More sharing options...
[Do...] Posted April 15, 2025 Author Share Posted April 15, 2025 Please sign in to view this username. it is unfortunate that my version does not have the caliper distance and adds complexity to some programs in order to achieve the same results. Link to comment https://qualityforum.zeiss.com/topic/23147-caliper-distance-not-available/#findComment-130393 Share on other sites More sharing options...
