Error, GEAR runs in the manual mode.
What is this error? it just pops up randomly. The program could be running fine and then it just pops up from one run to the next. It is so annoying because i have to end task for gear pro and calypso.
Is there anything i am doing that is triggering this? anyone else get this message and error?
Any screenshots which you can provide?!
How do you change from CALYPSO to GEAR PRO?
Via the Windows taskbar or via the change buttons in CALYPSO and GEAR PRO?
Sorry i didn't grab any but it is a single small window that pops up and it says "Error, GEAR runs in the manual mode."
I run GearPro through the gear icon in Calypso and also by running a program in calypso. It goes through the base alignment and then when it gets to the gear feature/characteristic, it gives that error and then alarms out.
