Auto populate user field in report
Is there a way to have Gear Pro auto populate what CMM is being used? Idea is to have all of our programs pulled from 1 central location to keep everyone running the most recent program. From there the operator only needs to add their name, no matter what CMM is being used to take measurements.
Thank You!
Yes with user fields from Calypso, it is a bit involved. If the 'operator' is logged into as Calypso under their name, you could have Gear Pro auto populate their name AND the machine it was inspected on.
  • Like! 1
  • 3 weeks later...
 building off of this. I got calypso piweb reports to update serial #, Operator, and CMM thru the ini file and the txt file. When I go over to gear pro, it reads the txt file options in the "Calypso protocol variables" and It is turned on and selected to protocol positions in my work piece documentation. The report header does reflect the updated titles of
CMM
Operator
Serial Number
However those boxes are still blank........
