[Jo...] Posted June 12 Share Posted June 12 Hi all, We’re currently experiencing an issue with one of our CMMs. Both machines are set up side by side. One is exporting Excel data as expected, while the other is only generating the header information in the Excel report—no measurement data is included. Both systems are exporting PDFs without any issues. My initial thought was that the Excel template file on the second CMM might be corrupted. I tried replacing it with the working template from the functional CMM, but that didn’t resolve the issue. I also replaced the INI file, again with no improvement. I wasn’t involved in setting up these machines and have limited experience with how Calypso handles Excel templates. If anyone has insight into how Calypso generates these reports or knows of other files/settings that might influence this, I’d really appreciate your input. Suggestions are very welcome! Thanks in advance! Link to comment Share on other sites More sharing options...
[Ri...] Posted June 12 Share Posted June 12 I need to follow this, because one day in the not too distant past, IT updated something, and my Offline seat creates blank excel files (Header data only). Excel365 Zeiss "xls" template. Oddly enough, none of the other live seats have an issue. Link to comment Share on other sites More sharing options...
[Za...] Posted June 12 Share Posted June 12 Joseph, you may want to look at this Knowledge Base Article for assistance. https://portal.zeiss.com/knowledge-base?id=1263814 this may also be related to some third party software like QC calc muddying the waters, in which case, that customer service team may be able to further assist. 1 Link to comment Share on other sites More sharing options...
[No...] Posted June 13 Share Posted June 13 Are there an security restrictions in effect on the computer, like Excel not being allowed to execute macros? I would focus my investigations on things like that. 1 Link to comment Share on other sites More sharing options...
[Ri...] Posted June 13 Share Posted June 13 Please sign in to view this quote. Seems to be missing information in those instructions. At the section: Updating Custom Excel Templates For Excel 16 or Higher Select the “ThisWorkbook.RunReport” Macro and click Edit (Dialog box is displayed in the instruction). The last instruction states: Select everything in the box shown below and copy this text. Open your custom report and follow the same steps to take you to the same Macro we just copied. Paste the copied text over the same area to replace your custom report with the new updated code. But there is not further information as to what should be copied. Link to comment Share on other sites More sharing options...
[Jo...] Posted June 13 Author Share Posted June 13 Please sign in to view this quote. Morning all, Thanks for all the feedback! I have tried 80% of the suggestions in the guide that Zak mentioned. None were successful unfortunately. Microsoft 365 is not applicable, so I didn't try to repair. We do use QC-calc, so I do want to adjust the retrieval time suggestion. Does anyone know where to find this setting in QC-Calc? If that doesn't work, I am going to try calling the hotline. Link to comment Share on other sites More sharing options...
[Jo...] Posted June 13 Author Share Posted June 13 (edited) Please sign in to view this quote. I was confused at first as well. The guide is describing to copy the new template macro code, that is found in the newest version of calypso public docs folder, into your old template macro module if I am not mistaken. Edited June 13 1 Link to comment Share on other sites More sharing options...
[DW...] Posted June 13 Share Posted June 13 Please sign in to view this quote. Please sign in to view this username. Open Excel. File>Options>Trust Center>Trust Center Settings>Macro Settings>Enable VBA Macros and Enable Excel 4.0 macros when VBA macros are enabled. You may also need to add the template path to the "Trusted Locations". Link to comment Share on other sites More sharing options...
[Jo...] Posted June 13 Author Share Posted June 13 Please sign in to view this quote. Thanks for the reply DWC. I did attempt this earlier with no success 😞 Link to comment Share on other sites More sharing options...
[Ky...] Posted June 13 Share Posted June 13 Hey Joseph, If you are using QC Calc, I would probably put money on that causing that. It usually uses the table files to import the data, but the Excel output in Calypso also uses these files, so you have 2 different software packages trying to access the data at the same time and the results are not predictable. As a test, I would either try to turn off QC Calc (I have no idea how to do that), or save the table files somewhere other than where you are saving them now (just in like a folder on the desktop) so that QC Calc does not know where to look for them. If the Excel report works after that, you have your cause. This document covers how to change the saving location of files. It should help with that test. https://portal.zeiss.com/knowledge-base?id=587888 1 Link to comment Share on other sites More sharing options...
[Jo...] Posted June 13 Author Share Posted June 13 Please sign in to view this quote. Thanks for the suggestion Kyle. I will def rule this out, but I wouldn't put money on it as we have 2 other machines with QC-calc running with no issues. I'm going to poke around before I leave today to hopefully. Ill also try to add that delay timer if I can find where the setting lives in QC-calc. I am also going to verify the INI File is located in the XLstart directory. This could have not been loaded when IT upgraded to Excel 16. Link to comment Share on other sites More sharing options...
[Ky...] Posted June 13 Share Posted June 13 I have seen this many times before. I've even seen it happen after updating. Some machines would work, others wouldn't. Having multiple programs going after the same file at the same time is not a good situation and it is completely unpredictable. Your other machines could hypothetically start doing this at any time as well. Unless there is another error that is popping up that I am unaware of, I'm pretty confident, especially if the data in the header area is correct. Link to comment Share on other sites More sharing options...
[Jo...] Posted June 16 Author Share Posted June 16 (edited) Please sign in to view this quote. Hey Kyle, You could be right, If QC is stealing the data, I will need to add that delay into the software, as mentioned in the link Zak posted. Do you know how to add a delay to QC-calc data collection? I am also getting the INI error below. I tried to drop that in the XLstart directory on Friday, but ran into a permissions issue that I need IT to help with. Edited June 16 Link to comment Share on other sites More sharing options...
[DW...] Posted June 16 Share Posted June 16 Please sign in to view this quote. Please sign in to view this username. Interesting, I have had this error since the beginning of using Calypso (Unable to locate ReportINI) whenever I open the XLS file generated from the run. I have just ignored it but if someone can give the fix for this, it would make my Excel compilation script even faster! Link to comment Share on other sites More sharing options...
[Jo...] Posted Thursday at 11:38 AM Author Share Posted Thursday at 11:38 AM Morning all, I believe I have fixed the issue on my end. I think the root cause is linked to that missing Report INI file in the xlstart directory. I had to get IT to drop it in the folder for me due to permissions. C:\Program Files (X86\Microsoft Office\Root\Office 16\XLSTART\ . This could be different on your machine. I don't have all the details on why this was the main cause. From my understanding, this file helps the macro's within the template file run more smoothly. for safe measures, I did add the QC-calc delay. Here are the steps to do this if you are using 3.3. Press Control + F8 keys to open the QC-Config window Select the QcCalcOverrides.ini tab Expand the DataCollectionSettings section There is a CalyDataCollectionDelay setting you can set in there. Restart QC-CALC Real-Time after making any changes in there if you are using 3.4 or higher, you need to go to tools>Edit Application Defaults. Then turn Data_Collection_Delay_Switch to "1" which enables the data collection delay. Next, you can change the Data_Collection_Delay_In_Seconds. I hope this helps others! 1 Link to comment Share on other sites More sharing options...
[DW...] Posted Thursday at 12:30 PM Share Posted Thursday at 12:30 PM Please sign in to view this quote. Please sign in to view this username. Dude... I never really put the work in to figure out the Report INI error, and you just solved it. This makes the following script for compiling the single XLS reports into one single file that much quicker without having to deal with the error window popup. Cheers to you sir! # Define the directory containing the XLS and XLSX files $directory = "PATH TO YOUR FOLDER CONTAINING THE XLS FILES FROM CALYPSO" # Create a new Excel application instance $excel = New-Object -ComObject Excel.Application $excel.Visible = $false # Convert .xls files to .xlsx Get-ChildItem -Path $directory -Filter "*.xls" | ForEach-Object { try { $workbook = $excel.Workbooks.Open($_.FullName) $newFileName = [System.IO.Path]::ChangeExtension($_.FullName, ".xlsx") $workbook.SaveAs($newFileName, [Microsoft.Office.Interop.Excel.XlFileFormat]::xlOpenXMLWorkbook) $workbook.Close($false) Write-Host "Converted: $($_.FullName) to $newFileName" # Uncomment the next line to delete the original .xls file # Remove-Item $_.FullName -Force } catch { Write-Host "Failed to convert $($_.FullName): $_" } } # Process .xlsx files Get-ChildItem -Path $directory -Filter "*.xlsx" | ForEach-Object { try { $workbook = $excel.Workbooks.Open($_.FullName) $worksheet = $workbook.Sheets.Item(1) $worksheet.Range("A1:H13").Delete() $workbook.Save() $workbook.Close() } catch { Write-Host "Error processing file $($_.FullName): $_" } } # Compile data into a new Excel file $destinationExcelFilePath = Join-Path $directory "compiledExcel.xlsx" if (Test-Path $destinationExcelFilePath) { Remove-Item $destinationExcelFilePath -Force } $destinationWorkbook = $excel.Workbooks.Add() $destinationWorksheet = $destinationWorkbook.Sheets.Item(1) $columnIndex = 1 Get-ChildItem -Path $directory -Filter "*.xlsx" | Sort-Object Name | ForEach-Object { $sourceWorkbook = $excel.Workbooks.Open($_.FullName) try { $sourceWorksheet = $sourceWorkbook.Sheets.Item(1) $sourceValues = $sourceWorksheet.Range("B1:B946").Value2 $destinationWorksheet.Cells.Item(1, $columnIndex).Resize(946, 1).Value2 = $sourceValues $columnIndex++ } finally { $sourceWorkbook.Close($false) } } $destinationWorkbook.SaveAs($destinationExcelFilePath) $destinationWorkbook.Close($true) # Quit Excel and clean up $excel.Quit() [System.Runtime.Interopservices.Marshal]::ReleaseComObject($excel) | Out-Null [System.GC]::Collect() [System.GC]::WaitForPendingFinalizers() Link to comment Share on other sites More sharing options...
[Jo...] Posted Thursday at 06:38 PM Author Share Posted Thursday at 06:38 PM Glad to have helped Please sign in to view this username. ! I only know about the XLStart directory as I use it for one of my macro workbooks. It was different on my PC vs the Calypso PC though. Link to comment Share on other sites More sharing options...
