[Br...] Posted 19 hours ago Share Posted 19 hours ago (edited) Is there a good way to add notes inside of a program, like a Notepad type of function? Specifically, I would like to be able to add a record of scan setting inside of a program. Appreciate any assist Edited 19 hours ago Link to comment Share on other sites More sharing options...
[Ja...] Posted 7 hours ago Share Posted 7 hours ago Hi Brian. There is a possibility to add notes to a project template such that you can see them when you are selecting the template to run the program from. Its a bit clunky but i think its a reasonable option. Hope this helps Link to comment Share on other sites More sharing options...
[Ch...] Posted 6 hours ago Share Posted 6 hours ago Depending on your task maybe the usage of annotation label could be a reasonable solution too. If you have templates and the note you like to take is always the same James solution could be a good idea. If not maybe annotation labels could help you. Link to comment Share on other sites More sharing options...
