[Lv...] Posted Tuesday at 03:36 AM Share Posted Tuesday at 03:36 AM Does anyone use bevel option to measure hirth tooth? I saw the manual can display the Topographic for hirth and worm wheel! Link to comment Share on other sites More sharing options...
[Ro...] Posted Tuesday at 09:12 AM Share Posted Tuesday at 09:12 AM This solution describes a topographical evaluation against nominal data. Nominal data either as ASCII point cloud data or as CAD file. If you have nominal data in that format you can realize a topographical nominal/actual comparison similar to what is done for bevel gears. An example printout is also visible in your screenshot on the lower right side. 1 Link to comment Share on other sites More sharing options...
[Lv...] Posted 22 hours ago Author Share Posted 22 hours ago When can we have a module for hirth gears?😁 Link to comment Share on other sites More sharing options...
