Gear pro bevel can measure Hirth tooth?
Does anyone use bevel option to measure hirth tooth? I saw the manual can display the Topographic for hirth and worm wheel!
This solution describes a topographical evaluation against nominal data. Nominal data either as ASCII point cloud data or as CAD file. If you have nominal data in that format you can realize a topographical nominal/actual comparison similar to what is done for bevel gears. An example printout is also visible in your screenshot on the lower right side.
