[ca...] Posted July 3 Share Posted July 3 (edited) Hello everyone, I am no longer able to use a feature that I was previously able to access in previous software versions AttributeError: module 'gom.api' has no attribute 'project' Has there been a change in the licensing to access the image acquisition command? The API command appears to be same in the 2025 documentation Thanks, Canset Edited July 3 Link to comment Share on other sites More sharing options...
[ca...] Posted July 3 Author Share Posted July 3 (edited) Is a Scanning-VMR licence required now for accessing gom.api.imaging? Could you please provide information on this? Thanks, Canset Edited July 3 Link to comment Share on other sites More sharing options...
[Ma...] Posted July 3 Share Posted July 3 Hi Canset, No, this is not related to the licensing scheme. The way gom modules are imported has been changed in ZEISS INSPECT 2025 - now you have add a dedicated import statement for each module, e.g. import gom.api.project import gom.api.imaging There is a hint in ZEISS INSPECT App Python API documentation — App Development Documentation, but for sure it can be overlooked easily. Best regards, Matthias 1 Link to comment Share on other sites More sharing options...
[ca...] Posted July 3 Author Share Posted July 3 Hello Matthias, Thank you very much for your prompt response. It solved my problem 🙂 Thanks, Canset 1 Link to comment Share on other sites More sharing options...
