AttributeError: module 'gom.api' has no attribute 'project'/ ZEISS Inspect 2025
Hello everyone,
I am no longer able to use a feature that I was previously able to access in previous software versions
Has there been a change in the licensing to access the image acquisition command? The API command appears to be same in the 2025 documentation
Thanks,
Canset
  • [ca...] changed the title to AttributeError: module 'gom.api' has no attribute 'project'/ ZEISS Inspect 2025
Hi Canset,
No, this is not related to the licensing scheme.
The way gom modules are imported has been changed in ZEISS INSPECT 2025 - now you have add a dedicated import statement for each module, e.g.
import gom.api.project
import gom.api.imaging
There is a hint in ZEISS INSPECT App Python API documentation — App Development Documentation, but for sure it can be overlooked easily.
Best regards,
Matthias
  • Thank you! 1
