Recall Feature Points from a Single Circle Path of a Cylinder, High Volume (Loop or Pattern)
Hi,
I want to extract/recall circle paths from a high volume of cylinders that have already been created and inspected. Due to the volume, I would like to automate the process.
Scope: The measurement plan contains a high volume of Cylinders (2000+). Each cylinder is commonly named Cylinder1, Cylinder2, etc. Each Cylinder contains the same strategy (5 circle paths) and evaluation. The pattern of the hole set is not consistent, meaning there is no consistent X and Y offset.
Goal: Use an automated process to recall the feature points of each circle path within the Cylinder. I.e., Cylinder1 → Circle1_1, Circle1_3, Circle1_5, where the underscore index represents the circle path.
I have coding experience but no direct PCM experience, so I was hoping to avoid PCM. But I'm happy to give it a shot. Any help would be appreciated.
If you right click on each feature, you can export points to a file and then recall those same points
into another feature. Or recall them directly from inside another feature. As far as the
lack of a pattern problem. I'm no help there. What is the end goal?
  • Like! 2
Thanks for the response. Let me add some extra information.
I would like to recall each scan path for each cylinder into a circle. Then, I would like to report the diameter size for each of these circular paths. Because there are over 2000 cylinders, I would like to avoid any manual process, such as your suggestion above.
You state: "The pattern of the hole set is not consistent, meaning there is no consistent X and Y offset". Do you have a model?
I do have a model, but I would be unable to upload it due. A screenshot of the pattern is below. Each hole shown represents a cylinder that was captured.
That's what I was thinking, but I thought it was worth asking. I had hope that I could use the recall feature points feature and add a loop to index each cylinder. However, I could not add a formula to the cylinder selection. I could add a loop to the feature point recall box for that specific feature, but that doesn't help much... 😑
My other idea was hoping there was a recallable feature attribute that I could reference in a single diameter callout. I'm aware that not all feature attributes are listed in the popup, so I was hoping that this was hidden as well.
I have to thank you for this topic! I've been working with Calypso for 18 years now, and only today found out that the feature(s) to be used in a point recall can also be parametrized with a formula (not just the point range). 😵🤯
But shame on uncle Carl, for the odd way in which this was implemented!
  • Awesome! 1
Update:
While playing around with my new knowledge I found out that while you can put a formula on the point recall and specify the features to use with list("Feature1", "Feature2",...) there seems to be no syntax that would allow to further specify which scanning path(s) to take from those features. Adding a point range from the context menu when a formula is already present, doesn't seem to work (it doesn't get stored permanently), so if it's at all possible to define an additional range, it would have to be part of the formula itself. Does anybody know if and how this can be achieved with the list() function?
That's a lot of cylinders.
Not the answer you're looking for, but for refence if you don't use it, anytime I want to use one feature to report the diameter and locations of the cylinder at different depths and cylindricity of all, I create individual circle features/strategies for each depth the cylinder is being measured at, group them together and then recall the circles into a stepped-cylinder feature.
The stepped cylinder allows you to report all the diameter sizes and locations in one group. I wish they could add the form/roundness to the stepped cylinder as well, but that has been brought up in Zeiss's "my voice" suggestions a few times, to no avail.
It may be easier to extract what you're looking for in a stepped cylinder, with filters applied,  with PCM?
  • Awesome! 1
@Norbert Bendl
Happy to help! And yes, I wish it were implemented in a better way. And can math/code the process in my head, but Calypso lacks the features 😢
I'm not sure if I am completely following. Are you trying to recall the features points of a uniform pattern? If so, I believe you should be able to use the cylinder function with formulas to get that done. You would have to adjust the formulas, but the following is an example. Adjust the X,Y,Z to start at your first hole. Assuming the cylinder is in the Z axis, the X and Y should be the nominal of your hole 1. The Z should include a buffer so that it always captures the first scan path of the cylinder. The diameter should also include a buffer to prevent issues caused by the actual size or X/Y offsets. Then I believe you should be able to pattern this feature to capture all holes.
Because my pattern is not consistent, I did not dive into this method. But if you give it a shot, let me know how it goes 😁
@Owen Long
Very interesting! I never considered a Stepped Cylinder, and that could be very helpful in the future. But the major issue I foresee is that instead of 2000+ cylinders, I would have 10000+ circles (2000 holes x 5 circle paths per hole). And I would need to be very specific with the naming convention so that I could use PCM to recall the 5 circle paths into the proper cylinder. I think you may be alluding to this with your final comment.
  • Like! 2
I'm not sitting in front of the computer now but this should get you started in PCM. I may need some tweaking.
// Declare the number of cylinders you want to process
numCylinders = 2000
// Loop through each cylinder
for i = 1 to numCylinders
  // Build base name of cylinder and circle subfeatures
  baseName = "Cylinder" + format(i)
  // Loop through each expected circle path (you mentioned 5)
  for j = 1 to 5
    circleName = "Circle" + format(i) + "_" + format(j)
    // Check if the feature exists in the plan
    if doesFeatureExist(circleName)
      // You can extract or log coordinates or do something with the circle path here
      xVal = getActual("Position", circleName).x
      yVal = getActual("Position", circleName).y
      zVal = getActual("Position", circleName).z
      // Print or write to file/log if needed
      println("Feature " + circleName + " position: X=" + format(xVal) + ", Y=" + format(yVal) + ", Z=" + format(zVal))
    else
      println("Feature " + circleName + " does not exist.")
    endif
  next j
next i
  • Like! 2
  • Awesome! 1
  I echo
.   Thanks for posting about this project.  I agree with you that the naming conventions will need to be specific.
Though it's a complex task, it is achievable.
, thanks for the possible PCM solution.  Very innovative.
I'll definitely be following this topic, and please keep posting updates on how it develops.
I wasn't trying to solve a problem of my own, but to find a way to a generic solution of yours. Since you can select the features to recall points from with a formula using the list(...) function, I wonder if it's also possible to further select single scan paths of a feature with list(...), in the same way you'd do it manually when you "open" a feature from the context menu in the strategy window. With such a formula and some PCM code I believe you could make a dynamic feature that would recall its points from the correct scan path of the correct cylinder depending on its own name. So you'd just copy it, rename it in a specific way and it would recall the points from a different cylinder/scan path.
  • Like! 3
Sorry, I was swamped with other projects and couldn't follow up sooner. I also put in a service request, so I have a couple of updates from that application engineer.
@Mark Boucher - Thank you for the support. The PCM code is very similar to the PCM code provided by ZEISS. Some slight differences, the PCM was based more on the nominals than the actuals. And the zValue, included a buffer to capture the offset actuals. I can not validate that your code works, but worst case, it would just need a few modifications.
But unfortunately, the ZEISS application engineer confirmed that there is no better way to complete this process. He felt that the concept was interesting enough that it should be considered in My Voice. I was just a little disappointed since all the data is there, but there is no easy way to streamline it. 😭
Would this work for you?
Short explaination:
Cylinder1-Cylinder11: My try to mimic your current program.
CylinderX(11): Recalling each cylinder individually in a pattern
Circle_1(11) - Circle_5(11) - Recall the individual paths from the cylinder into 5 separate circles.
Testplate.zip
No PCM at all.
The pattern is for collection all the individual cylinders in a single cylinder with a pattern to make it easier to work with.
This is done with formulas in all the characteristics fields with getNominal() to mimic the values from the individual cylinders and with a formula in the recall feature points window. In Calypso 6.8 which I use it is a bit tricky to find the formula dialog. I don't know if they have fixed this in later versions but if you are having problems finding it, just tell me and I will describe it to you.
From the cylinder with a pattern I can recall the individual measurement paths (in the recall feature points window, right click on the cylinder and click Open) into the 5 circles with a pattern and then I can evaluate whatever I want with them.
In the characteristics list I removed the loop from the individual diameters and put the loop on the group instead. This doesn't really change anything other than you get all the different evaluations of a single cylinder grouped together in the printout instead of all sections 1 and then all sections 2 and so on.
Appreciate the response. It's really clever.
When I tried reverse engineering it and making my own version, I got stuck at exactly where you mentioned, the recall feature points window with formula. I cannot for the life of me find anywhere to input or even view any formula in the recall feature points window. I've never seen the list "yellow", and it's actually why I thought there was PCM involved lol.
Would you mind describing where to view that at? I'm also on 6.8.
The trick is to right click in an area not occupied by a feature name. The problem is that the feature names expands all the way from left to right and nowadays the vertical height of the feature names perfectly covers the vertical expansion of the window itself. In previous versions it was possible to right click on a small area below the last name in the list but not anymore.
First you need to empty the list. The easiest way is to write something in the filter field (the white field below "Elements") that will get no hits. Just type ASDF in the field and the list empties. Then you can right click in an empty place to get access to the formula dialog.
  • Like! 2
That's why I said shame on them for the way this was implemented. It took me 18 years and this thread to even discover this functionality 🤯
