Self-centering point suggestions
Looking for suggestions for settings on a self-centering point.  In the pic below, view is from -Y)  I am using a 0.8 stylus to measure the depth of a step that is 0.5 wide. Though this will be done with VAST Gold head, sometimes when using a star probe on an XXT, there is a tendency for the probe to glance of the step and slide past the step.  I'm thinking a self-centering point with some force towards the side wall, along with force in the probing direction might help.  I am also taking a point on the side wall to help control the location of the point on the step, so I can get as close as possible.  I am also considering lowering the probing dynamic.  How would you guys approach this?
 I am measuring the depth of the step where the tip of the probe is at and want to make sure the probe doesn't slip off the step.
On that wall parallel to the shaft probe a point. Create a secondary alignment using that point (XYZ).
Place a nominal point feature on the other surface recalling that secondary alignment. insert a formula to put the point at 0.45 in Z.
Exactly as you said: I have often needed to execute a self-centering point with some force directed at the side wall. I would target 45 degrees, use a midpoint evaluation, and use a formula to calculate the point of contact.
  • Like! 2
In the past, I would probe a point on the side wall, use that for my location control from the side wall (PCM) to probe the point you require.
Now it will always be X amount from the side wall ensuring your contact is good for the point you require.
Although I am loathe to do any trial and error with a 0.8mm, it may be worth experimenting with the clamping of the machine axis during self centering, or using the "own selection" to set the directional forces. Adding a bit of downward force will likely help keep the probe from slipping off. My screenshot is from a +Z point in an empty program, so the Fz is simply -200 by default
I had trouble with using "Own Selection".  No matter which values I used, it would slide off the step.  I ended up using a touch point but modified the vector to come at an angle less than 45° and used "Probe in Normal Direction".   Haven't confirmed the results yet.
  I did both and got the same exact result.  Touch point reports to closest primary axis, which is X, so vector doesn't matter, as long as more X than Z.
Checked depth in Z direction with .5 probe and result was within .0002".  I'm going home and taking my ball with me.
  • Like! 2
 Not a hole. But that does remind me that I have had relatively good results using Step Points.
