[To...] Posted July 25 Share Posted July 25 Looking for suggestions for settings on a self-centering point. In the pic below, view is from -Y) I am using a 0.8 stylus to measure the depth of a step that is 0.5 wide. Though this will be done with VAST Gold head, sometimes when using a star probe on an XXT, there is a tendency for the probe to glance of the step and slide past the step. I'm thinking a self-centering point with some force towards the side wall, along with force in the probing direction might help. I am also taking a point on the side wall to help control the location of the point on the step, so I can get as close as possible. I am also considering lowering the probing dynamic. How would you guys approach this? Link to comment Share on other sites More sharing options...
[Cl...] Posted July 25 Share Posted July 25 Maybe I'm not quite understanding exactly what you are trying to do, but why not measure a line on each surface and intersect them for a point? Link to comment Share on other sites More sharing options...
[To...] Posted July 25 Author Share Posted July 25 (edited) Please sign in to view this username. I am measuring the depth of the step where the tip of the probe is at and want to make sure the probe doesn't slip off the step. Edited July 25 Link to comment Share on other sites More sharing options...
[Cl...] Posted July 25 Share Posted July 25 (edited) OK. I didn't see that at first. I thought it was just the corner of some square geometry. Edited July 25 Link to comment Share on other sites More sharing options...
[Cl...] Posted July 25 Share Posted July 25 (edited) On that wall parallel to the shaft probe a point. Create a secondary alignment using that point (XYZ). Place a nominal point feature on the other surface recalling that secondary alignment. insert a formula to put the point at 0.45 in Z. Edited July 25 1 Link to comment Share on other sites More sharing options...
[Cl...] Posted July 25 Share Posted July 25 I guess you don't need a formula. Just 0.45 in Z from the secondary alignment. Link to comment Share on other sites More sharing options...
[Ke...] Posted July 25 Share Posted July 25 Exactly as you said: I have often needed to execute a self-centering point with some force directed at the side wall. I would target 45 degrees, use a midpoint evaluation, and use a formula to calculate the point of contact. 2 Link to comment Share on other sites More sharing options...
[To...] Posted July 25 Author Share Posted July 25 Please sign in to view this username. Seems like a touch point would still calculate to the tip, but I will try both and compare. Link to comment Share on other sites More sharing options...
[Ni...] Posted July 25 Share Posted July 25 I'd personally just try a single point with the feature aligned on the nearest surfaces with the probing dynamic turned down to 12.5% Link to comment Share on other sites More sharing options...
[Ri...] Posted Monday at 10:58 AM Share Posted Monday at 10:58 AM In the past, I would probe a point on the side wall, use that for my location control from the side wall (PCM) to probe the point you require. Now it will always be X amount from the side wall ensuring your contact is good for the point you require. 1 Link to comment Share on other sites More sharing options...
[Ke...] Posted Tuesday at 01:36 PM Share Posted Tuesday at 01:36 PM Although I am loathe to do any trial and error with a 0.8mm, it may be worth experimenting with the clamping of the machine axis during self centering, or using the "own selection" to set the directional forces. Adding a bit of downward force will likely help keep the probe from slipping off. My screenshot is from a +Z point in an empty program, so the Fz is simply -200 by default Link to comment Share on other sites More sharing options...
[To...] Posted Tuesday at 02:48 PM Author Share Posted Tuesday at 02:48 PM I had trouble with using "Own Selection". No matter which values I used, it would slide off the step. I ended up using a touch point but modified the vector to come at an angle less than 45° and used "Probe in Normal Direction". Haven't confirmed the results yet. 1 Link to comment Share on other sites More sharing options...
[Ke...] Posted Tuesday at 03:58 PM Share Posted Tuesday at 03:58 PM caddyshack-judge-smails.mp4 Link to comment Share on other sites More sharing options...
[Ri...] Posted Tuesday at 04:08 PM Share Posted Tuesday at 04:08 PM If you are going to probe in the direction, I would personally feel safer using mid-point, and just offsetting the probe radius manually. I'd be nervous of incorrect vector compensation. 1 Link to comment Share on other sites More sharing options...
[To...] Posted Tuesday at 07:43 PM Author Share Posted Tuesday at 07:43 PM (edited) Please sign in to view this username. I did both and got the same exact result. Touch point reports to closest primary axis, which is X, so vector doesn't matter, as long as more X than Z. Checked depth in Z direction with .5 probe and result was within .0002". I'm going home and taking my ball with me. Edited Tuesday at 07:44 PM 2 Link to comment Share on other sites More sharing options...
[Ma...] Posted Tuesday at 08:40 PM Share Posted Tuesday at 08:40 PM Tom, if possible, put a known gage pin in the hole touch the top and use a formula to subtract the difference using Result Element. Link to comment Share on other sites More sharing options...
[To...] Posted yesterday at 01:15 PM Author Share Posted yesterday at 01:15 PM (edited) Please sign in to view this username. Not a hole. But that does remind me that I have had relatively good results using Step Points. Edited yesterday at 01:17 PM 1 Link to comment Share on other sites More sharing options...
