How to get more points in a section
  • 2 weeks later...
Hello Hanna,
did you try another postprocessing method like "more details" in the polygonization dialog?
During acquisition make sure that "Full resolution" is used during scanning and a smaller measuring volume will increase the resolution, too. Movement of the part during measurement might also lead to a less detailed scan.
More scans of the same area might even lead to a smoother mesh, because there are more overlapping areas which have to be evened out, to get a single surface after polygonization.
There is also the possibility to use tools in the Mesh editing workspace like refine mesh, or under Operations -> Section -> Sample section to get more points on a section element. But these methods will not increase the resolution of the measurements directly of course.
Nanno
