[Ha...] Posted August 18, 2025 Share Posted August 18, 2025 We have been scanning and exporting sections of a mesh. However we need to have more points. We scanned with a rotation step number o 5 and have tried to double it to 10 but we still get the same amount of points. Why? Double number of images should get double the points... or? Link to comment Share on other sites More sharing options...
[Na...] Posted September 2, 2025 Share Posted September 2, 2025 Hello Hanna, did you try another postprocessing method like "more details" in the polygonization dialog? During acquisition make sure that "Full resolution" is used during scanning and a smaller measuring volume will increase the resolution, too. Movement of the part during measurement might also lead to a less detailed scan. More scans of the same area might even lead to a smoother mesh, because there are more overlapping areas which have to be evened out, to get a single surface after polygonization. There is also the possibility to use tools in the Mesh editing workspace like refine mesh, or under Operations -> Section -> Sample section to get more points on a section element. But these methods will not increase the resolution of the measurements directly of course. Nanno Link to comment Share on other sites More sharing options...
