Make this make sense
Position is different if I pick individual datums vs base alignment. They both should be the same? Also if I calculate position, it should not be 0.4073 ( 2√(0.0843²+0.0167²)
I think you should have selected: Plane A, 3d Line1, Circle B - i don't want to use this type definition of an alignment. I rather use normal alignment, where is realy shown where is origin.
Unless you have not fully defined alignment.
I think I remember seeing a post not long ago talking about the difference between
two alignments using the exact Datum's, as in this instance.
I thought it had something to do with Evaluation Method for Datum -
LSQ Feature
Outer tangential feature
ISO 5459
This is more confusing than anything. If print called for position to AB and I can't just plug in A and B. Depending on combinations of base alignment and/or A and B, I get like four different results.
