Popular Post [Iv...] Posted August 27, 2025 Popular Post Share Posted August 27, 2025 Hey guys, I put this quick guide together on stylus materials — figured it might be useful to have around the shop. Nothing too fancy, but it gives a simple breakdown of which styli work best for different situations, and a couple of reminders on wear and care. Figured this might be old news for most of you, but maybe it could help some of the entry-level users and peers around the shop. It's a single page, so it would be easy to have it near your CMM. Give it a look when you get a chance — and hopefully it saves us some time (and a few styli) down the road. Let me know if you feel like anything needs to be edited. CMM Styli Guide ZF.pdf 12 1 1 Link to comment Share on other sites More sharing options...
[Ch...] Posted August 28, 2025 Share Posted August 28, 2025 Ivan, Thank you - well done , sir. Stylus material is very important. Tip : there is also sapphire stylus however these are more rare, they are nearly identical to ruby, however might have a blue/purple color if you prefer over red 😁 Cheers, and happy measuring !! 2 Link to comment Share on other sites More sharing options...
[Ow...] Posted August 28, 2025 Share Posted August 28, 2025 Nice work! I'll add in that the extensions used on the styli are critical as well, especially on long extensions. You usually get what you pay for and while expensive, the silver high-end Carbon fiber Zeiss Reach CFX extensions are worth their weight in gold. I've used the cheaper, long carbon fiber extensions sold by other styli providers and their rigidness is not the same. 1 Link to comment Share on other sites More sharing options...
[Iv...] Posted August 28, 2025 Author Share Posted August 28, 2025 @Chris Rotolo Thank you, kind sir. Interesting, I was unaware of a sapphire stylus being an option. I considered including the tungsten carbide material, but I felt that it's really its own niche field, as it's most commonly used for gear measurement. I figured if you're already in that club, you probably don't need this info 😅 1 Link to comment Share on other sites More sharing options...
[Iv...] Posted August 28, 2025 Author Share Posted August 28, 2025 @Owen Long Thank you, I appreciate it. I would eventually like to add extensions to the guide; they go hand in hand. But I was one trying to keep this condensed to a single page, you can't rely on people flipping over the page these days 😂 Also, more importantly, this guide was driven by an RCCA. We measure a surprisingly high amount of silicon carbide, a very unforgiving material for those unfamiliar. Luckily or unluckily, it doesn't take too long to become familiar with the stylus (hopefully). However, with new programmers/operators, I'm not as diligent in expressing this knowledge and concern. Further story below for those interested. Also, I agree with you completely about your thoughts on extensions. ZEISS is completely in its own league. Cost will always be a factor, so like you, I've tried the other brands. But in this area, I would agree that it's really one of the areas where you need to spend up. More often than not, I find myself breaking down other stylus systems so I can use the ZEISS extensions rather than using off-brand ones that are just sitting there. Recently, in our lab, we had a job involving silicon carbide — a highly abrasive material. A programmer, unfamiliar with its properties, began scanning the surface with a silicon nitride stylus. By the time I caught on, multiple scans had already been completed. To the naked eye, the stylus looked fine. But when we pulled it under a microscope, a flat spot was immediately visible. The lesson? Styli wear is real, and it can happen faster than you think — even when you can’t see it. I didn't intend to toot my own horn with this post. But I made a LinkedIn article with the full story. Ultimately, the goal is to use this article and RCCA to push for the purchase of more diamond styli 😁 2 Link to comment Share on other sites More sharing options...
[Wo...] Posted August 28, 2025 Share Posted August 28, 2025 Please sign in to view this quote. Had the same situation. Had to re-measure ~50 pcs again. The top of the sphere was worn 0.002". Curiously, the Tensor calibration was not picking it up as it doesn't hit the sphere with the top of the probe (geometry re-qualification does). At the time it was decided that we're going to stick to ruby probes as silicon carbide was giving us too many issues. Please sign in to view this quote. Thanks to the above situation I've convinced the boss to get a diamond 3mm probe with carbide shank - it's an indestructible beast 😄 2 Link to comment Share on other sites More sharing options...
[Za...] Posted September 4, 2025 Share Posted September 4, 2025 Ivan's PDF looks really valuable, and for anyone visiting this post in the future, below is a link to a Knowledge Base Article which has a more in depth Styli Guide https://portal.zeiss.com/knowledge-base?id=1113662 2 Link to comment Share on other sites More sharing options...
[Iv...] Posted September 16, 2025 Author Share Posted September 16, 2025 @Zak Stehlin Thanks! I agree that it is a deeper dive and more insightful for anyone looking for a comprehensive view of everything stylus-related. My only issue with the guide is that it is a little drawn out, which causes some people to tune out. I believe the target audience for the guide I created is operators and entry-to mid-level programmers. I felt that they benefit best from smaller, bite-sized guides. Link to comment Share on other sites More sharing options...
[Lu...] Posted September 23, 2025 Share Posted September 23, 2025 Is there a way to clean the build-up from styli? Link to comment Share on other sites More sharing options...
[To...] Posted September 23, 2025 Share Posted September 23, 2025 (edited) Please sign in to view this username. I read a post (not on this forum) that they used lye (sodium hydroxide or potassium hydroxide). CAUTION Read up on these chemicals before using. Edited September 23, 2025 Link to comment Share on other sites More sharing options...
Popular Post [Ch...] Posted September 23, 2025 Popular Post Share Posted September 23, 2025 Please sign in to view this quote. Please sign in to view this username. What I'm about to say is considered blasphemy. But you can clean aluminum build up off ruby probes by using extra fine scotch brite and alcohol. Then cleaning with lint a lint free cloth. I admit, it is possible to remove material by being too aggressive with the scotch bright. But I have good data to support that it's not nearly as bad as people claim. I'll check our high use probes that have been cleaned many times using this method using our Zeiss microscope, Keyence Microscope, and using the Styli Roundness Scan that is attached. I have not found any significant wear that I can attribute to the scotch bright cleaning. Derek Stedman originally contributed the roundness scan and I make no claims to have created it. But it's a really cool program that checks the probe against the reference sphere and outputs roundness plots for your probes. Styli Roundness Scan.zip 5 Link to comment Share on other sites More sharing options...
[Wo...] Posted September 24, 2025 Share Posted September 24, 2025 I think I've seen a post somewhere about using muriatic acid to clean aluminum off ruby, but it was so long ago it might have been on the old forums. Never tried it though. In general, when I see a significant buildup that's affecting measurement I will just replace the probe. But I don't have the machines scanning aluminum 24/7 so it doesn't happen often. Please sign in to view this username. Could you give some more info about that program? Do I just locate the reference sphere with a master probe and then just run it using position points only like a probe qualification plan? Link to comment Share on other sites More sharing options...
[Ch...] Posted September 24, 2025 Share Posted September 24, 2025 Please sign in to view this username. Kinda, you'll locate the reference sphere like normal. Then the program has PCM in the program that will drive your probe into the reference sphere and output roundness plots to see any wear on the probe. Link to comment Share on other sites More sharing options...
[Iv...] Posted October 1, 2025 Author Share Posted October 1, 2025 I'm happy, people are still getting use out of this thread! Please sign in to view this username. ZEISS's ultimate recommendation is to replace the stylus if the buildup can not be fully cleaned up using a light cleaning solution. Maybe I'm just connecting dots, but it's a little convenient for them to say this since most will probably get the replacement from ZEISS 😆 A little while ago, I heard about a new automated cleaning brush that ZEISS was releasing. I couldn't find it available in the United States, but it appears to be available in other countries. But this looks more focused on cleaning a stylus, and it would not remove aluminum buildup. Admittedly, I have not been too aggressive in this area. My general cleaning solution is isopropyl alcohol. Working in California makes it difficult to hold any harsher chemicals, especially on your worksite. My general protocol is to use the proper stylus material for the part. Obviously, this doesn't always work out. I'll still keep styli with buildup and use those more comfortable jobs where I can justify the uncertainty in the buildup. Side note, I have used muriatic acid (Hydrochloric acid) to remove aluminum buildup from thread gages. You could see the reaction immediately happen, and I think those thread gauges eventually failed when the calibration was due. So I wouldn't recommend it for cleaning styli. 1 Link to comment Share on other sites More sharing options...
[Iv...] Posted October 1, 2025 Author Share Posted October 1, 2025 Please sign in to view this username. Interesting! I definitely give that a download and check out the Styli Roundness Scan recipe. Have you found that it can properly detect aluminum buildup? Also, what is the smallest diameter that you are comfortable using Scotch-Brite with? Link to comment Share on other sites More sharing options...
[Ch...] Posted October 1, 2025 Share Posted October 1, 2025 Please sign in to view this username. Under 1.5mm it gets difficult to use the Scotch Brite. We use it on some of our .8mm probes, but you have to be careful, and it is less effective. For anything 3mm and above it works great. You have to make sure to get 'extra fine' or 'ultra fine' scotch brite. usually its called 'extra fine hand pads' or something. 1 Link to comment Share on other sites More sharing options...
[Iv...] Posted June 1 Author Share Posted June 1 (edited) Please sign in to view this username. No rush, but I had a couple of questions about the styli roundness scan program that you attached. If you could provide some feedback, it would be greatly appreciated. When do you consider the stylus unusable? If any of the characteristic reports OOT? Or is it more involved? Did the custom report templates provide any extra insight? The reports did not appear to be included, so I used a standard PiWeb report Have you found any use of the stylus deemed no good? Any replacement methods? Have you been able to detect/quantify aluminum buildup in the reporting? Thanks! Edited June 1 Link to comment Share on other sites More sharing options...
[Ch...] Posted June 2 Share Posted June 2 Please sign in to view this quote. Please sign in to view this username. This is the million dollar question. And I have the most generic answer for you; It depends. Our average value for roundness is .4 - .6 microns. Anything above 1 micron gets me nervous, but I might still use it depending on where the probe is used. Anything above 2-3 microns and I'm probably calling it bad. We're using Prismo's, Micura's, and Accura's by the way. Please sign in to view this quote. Not really. I track all roundness and diameter values in a database(not PiWeb). I'm more concerned about change over time. I want to see that the probe's roundness and diameter results are not trending. I think I posted Derek's original program, but the one I use uses PCM to save the stylus and probe user defined header fields in my database. So I can query that and look for trends over time. I also changed the program to use a 25.4mm reference sphere that we have. All cmm's use the same reference sphere to run this roundness scan. I did that because I wanted to eliminate variables of using different reference spheres. Please sign in to view this quote. No. I heard there was a place that could replace the ruby, but we just buy new probes. We're in the turbo charger/ super charger industry and we have several tolerances that are insanely tight. So I want probes that are in good condition. However, you could probably use your 'bad' probes to measure stuff like castings. There's lots of measurements where you don't need a 'perfect' probe. The one thing to keep in mind, is that the deviations you see graphed are of the reference sphere, not the probe. So you need to invert the positive/negative areas you see on the graph so to speak. Kinda like this in my crude drawing. 1 Link to comment Share on other sites More sharing options...
[Iv...] Posted June 3 Author Share Posted June 3 Please sign in to view this username. Thanks! That all makes sense. I appreciate the extensive response. Maybe given your tolerance, it doesn't make sense to go down this route. Q-Mark does replace damaged stylus; these repair costs are a fraction of the cost of buying a new stylus. Please sign in to view this quote. This is very interesting and a great idea! But it also makes the most sense once you dig a little deeper. The stylus arrives with a quantifiable form deviation. To predict/review trends, a baseline would be needed. Are you performing this stylus check as PM (preventive maintenance)? If so, what is your frequency? Or are you only performing this check as needed/before a qualifying inspection? We currently perform a quarterly stylus check as part of our PM, but our method could use improvement. Have you found a way to automate this process? I'm thinking something similar to the "Probing system qualification" characteristic function built into Calypso. This would allow you to select multiple styli. And assuming these styli are properly defined in your system, this could then be treated as a program and run in the background. Normal star stylus would have to be split into two sets; image below, where only red styli are checked against the current ref sphere orientation. But the output would be something more similar to Derek's program. I did not dig too deep into the program, but it appeared that the PCM only recalled the currently active stylus. Link to comment Share on other sites More sharing options...
[Ch...] Posted June 4 Share Posted June 4 Please sign in to view this quote. Right now, I tell my operators to run the program as often as they can as they get free time. We have a lot of probe systems and it takes time to populate the database to the point you can detect trends. Then we examine any questionable probes under our microscopes. We have an AmScope and Leica microscopes. I would like to create a more formal system and put this on a set schedule. I have a written procedure and logbook ready to go for this; but I haven't implemented it yet. If you are using a database, you want to make sure your operators are labeling the correct probe. To help with this, I use PCM to pull the probe name and set record head, that way there is no way an operator can name it wrong. Something like this in the PreSettings: Probe=getProbe().confName +" "+ getProbe().probeName setRecordHead("u_IHI_Lot",Probe) 2 1 Link to comment Share on other sites More sharing options...
[Ri...] Posted 3 hours ago Share Posted 3 hours ago (edited) Please sign in to view this quote. I use Red Cratex, sometimes Brown. You can rub or spin the sphere on the Cratex, it will clean it quite well. I examine the spheres under 7x and 10x. I have been doing this for about 18+ years extending the life of styli 10x in most diameters (1mm is difficult due to breakage). Do not spin the Cratex with a motorized device, spin the stylus instead by hand or motorized device at slow rpms. Edited 3 hours ago 1 Link to comment Share on other sites More sharing options...
