[Br...] Posted August 29, 2025 Share Posted August 29, 2025 Hello all, is there a way to display dimensions from all stages in one table? For example, the dimensions below are for the initial stage, I have many other stages, would like to know if there is a way to get all of the dimensions across stages to all be encompassed within one table. This would make a nice report page, and would definitely make export easier, to utilize in excel, all in one export. Any help appreciated, == as always Link to comment Share on other sites More sharing options...
[DW...] Posted August 29, 2025 Share Posted August 29, 2025 Please sign in to view this quote. Please sign in to view this username. You are going to have to modify the "Statistics Overview" Template and then save it as your own. It requires some tinkering, but with a single click I can export hundreds of stages of data into one Excel file at once. 1 Link to comment Share on other sites More sharing options...
[Na...] Posted August 29, 2025 Share Posted August 29, 2025 There is also a CSV based stage export: https://techguide.zeiss.com/en/zeiss-inspect-2025/article/cmd_internal_sys_export_gom_xml_csv.html Link to comment Share on other sites More sharing options...
[Br...] Posted August 29, 2025 Author Share Posted August 29, 2025 Please sign in to view this quote. Hey DWC, appreciate the reply, can you point me to any assist on walking through the modification? Appreciate any assist here Link to comment Share on other sites More sharing options...
[Br...] Posted August 29, 2025 Author Share Posted August 29, 2025 Please sign in to view this quote. Thanks, Nanno, this is very helpful as well! Link to comment Share on other sites More sharing options...
[DW...] Posted August 29, 2025 Share Posted August 29, 2025 (edited) Please sign in to view this username. It's not too complicated. Go to one of your project files that has multiple stages with all your dimensions. Now click to show your table, and from the template drop down select "Statistics RPS" This is one of the stock templates. Click the "Edit" button to the right. This creates a copy of the stock template that you can edit for your own needs. In "Edit" mode, you can right click the cells, and select edit. A new box will appear, where you will see the expressions and or functions that identify what appears in the cell. You can edit the formatting too, and add colors based on the results. You can add columns, delete columns, add rows, delete rows. Once you have it like you want, save your template with whatever name you want. Add the custom template to your "add ons" by clicking on "Manage Templates" at the bottom of your template drop down menu. You are going to have to play around with it to get a feel for how it works. Once you save the custom template to your "add ons" it will be available in every project file from that point forward as an option under "templates". Edited August 29, 2025 STATISTICS RPS Link to comment Share on other sites More sharing options...
[Br...] Posted August 29, 2025 Author Share Posted August 29, 2025 Please sign in to view this username. , thanks for this, will dig into this and see what I can accomplish, appreciate! Link to comment Share on other sites More sharing options...
[Br...] Posted September 4, 2025 Author Share Posted September 4, 2025 So, trying the "Export Stage Data", I can either of the below outcomes (one is simply deviation, the other has a lot of information, just not the one variable that I need 😵. Unfortunately, the one single thing I am looking for is a simple diameter. Either I'm missing something that seems like it should be obvious, or this is unnecessarily complicated... Any assist appreciated Link to comment Share on other sites More sharing options...
[Na...] Posted September 8, 2025 Share Posted September 8, 2025 Hi Brian, the CSV stages is somewhat predefined, but you could edit your table to show the measured values instead of the deviations: stages measured value.mp4 (the header should be changed from "DEV" to stage name for example I just realized) Nanno Link to comment Share on other sites More sharing options...
[Br...] Posted September 9, 2025 Author Share Posted September 9, 2025 Hi Nanno, appreciate the reply, this seemed to be working well, until I exported. File-Export-Stage data still sends the deviation only. As exported: Using "table template for export" I can get it to export the measured value, but only currently viewed stage, when I need to export all in a table. I am missing a piece of the puzzle here, seems like this would be a simple task, but apparently not with me at the helm 🙂 Link to comment Share on other sites More sharing options...
[DW...] Posted September 9, 2025 Share Posted September 9, 2025 (edited) Please sign in to view this quote. Please sign in to view this username. When you export the table, do your settings look like this? Edited September 9, 2025 Link to comment Share on other sites More sharing options...
[Na...] Posted September 10, 2025 Share Posted September 10, 2025 Brian, you need to edit and export the table template "Statistics RPS" like in my video - the template you are using displays only the values from the current stage. 1 Link to comment Share on other sites More sharing options...
[Br...] Posted September 10, 2025 Author Share Posted September 10, 2025 That was what i had missed, thanks all! Link to comment Share on other sites More sharing options...
