[An...] Posted 16 hours ago Share Posted 16 hours ago Hi! Having a discussion about the appropriate way to measure the distance between planes. One party says to just pick the Z direction. The other says to use the cartesian distance. The cartesian distance happens to match the supplier. I don't fully understand how the distances are calculated in the the magic box that is calypso... Any insight would be greatly appreciated! 🙂 Link to comment Share on other sites More sharing options...
[Za...] Posted 16 hours ago Share Posted 16 hours ago Cartesian is almost always the correct answer with plane to plane distances. the important nuance here is if the two planes are differently sized, to select the smaller plane for feature1 and the larger plane for feature2. the evaluation is from the center of feature 1 perpendicular to feature 2. below is an illustration citing the reason for small feature as feature1. 2 Link to comment Share on other sites More sharing options...
[An...] Posted 16 hours ago Author Share Posted 16 hours ago Thank you! Link to comment Share on other sites More sharing options...
[Ma...] Posted 15 hours ago Share Posted 15 hours ago We often use caliper distance to cover min-max. Then cartesian distance is a good one. I would never use just XYZ from features - mostly it's one corner on planes or origin of cylinder. If you have intersections or circles, then reporting XYZ is ok if it's according to drawing ( like from center of block and you would have to place theoretical feature into origin of that alignment ) 2 Link to comment Share on other sites More sharing options...
[Cl...] Posted 15 hours ago Share Posted 15 hours ago Keep in mind how each plane is being evaluated as well. Outer Tangential/Inner Tangential/LSQ. Each giving you the min/max/average distance respectively. 1 Link to comment Share on other sites More sharing options...
[Ed...] Posted 6 hours ago Share Posted 6 hours ago Hi, Look at this, this one is very helpful 🙂 LNL Distance.pdf 2 Link to comment Share on other sites More sharing options...
[na...] Posted 5 hours ago Share Posted 5 hours ago (edited) Please sign in to view this quote. If you have features of size, you can use Two-point distance characteristic. With this of course expect rolling eyeballs from people not knowing what to do with 2 results. Edited 4 hours ago Link to comment Share on other sites More sharing options...
