Remove part of a CAD model
I have a CAD model with 5 DE-STA-CO Clamps as part of the model along the back side of the fixture. Is it possible in Calypso to remove 1 of the clamps?
TIA
If you have an assembly model, then it's easier.
You can go to menu CAD -> Modify CAD entities, there you can select faces and hide them or remove them.
Assuming each of the entities are separate model, n the Modify CAD entities window mentioned by Martin, you can click the Edit Body tab and then you can select the each separate item. Delete or Hide
 Also, in the Modify CAD window, there is a "Hierarchy" tab.  There, you can tick/un-tick display of individual elements or bodies.  Right-clicking on the item also offers you the choice of hiding or deleting items.
I swear by half an hour of handpan healing music in front of my Calypso seat every morning 😄
I don't need to heal our NX models at all. All I'm doing is to remove free lines and points and to merge faces with same geometry. That's enough and doesn't affect the assembly structure.
  • Like! 4
