You had me at charcoal.
What makes you think the registry is involved here?
It doesn't work up to Calypso 2024, so it's a 2025 and upward only thing.
This, see highlighted text.
It seems like a hint using the word "Registry", my mind would naturally want to see registry entries.
Can you tell me again exactly which directory the file needs to be copied to?
Is it "c:\Users\Public\Documents\ZEISS\Calypso 8.0"?
If you have PCM, you can also put everything after the "=" in an executeCode() statement and evaluate it (don't forget to enclose in double quotes then)
  • 4 months later...
Could someone explain how to do it again? I have recently updated to calypso 2025 and wanted to test this out but it doesn't seem like i can access the video anymore. Do i take:
Dark Mode=UI.Skins.SkinRegistry current isLightSkin ifTrue: [UI.Skins.SkinRegistry factoryMethodSelector: #emulatedWindowsDarkSkin] ifFalse: [UI.Skins.SkinRegistry factoryMethodSelector: #calypsoSkin].
and put it into a text document in the:
C:\Users\Public\Documents\Zeiss\CALYPSO
folder? if so what should it be named? I think i remember doing it like that before but i am not sure. Thanks!
It needs to be in the text file called specialmenu.txt or something like that.   You should be able to search the forum and find the specific name.
Then I think it needs to be in the program folder. but root of the default program directory might work too.
  • 1 month later...
