[Ow...] Posted Tuesday at 11:41 AM Share Posted Tuesday at 11:41 AM Everything is in inch units. The big bore 4.1355 (Gerotor bore) is a direct offset in the Y axis. How would you constrain/clock this with only the 0.1969 offset as the planar axis and get good repeatability? I’ve tried measuring the middle bore as a cylinder and constructing a 3D line to intersect with the bottom of the 1.440 face and then the 4.1355 cylinder the same way intersecting with the same face and then creating a line between the two intersects for planar, but the offset always shows the x axis off one way or the other (non -repeatable), which effects the offset dimension. Each Cylinder is being measured with 3 equally spaced circle paths and then recalled into a 3D line. The alignment is looped. Link to comment Share on other sites More sharing options...
[Cl...] Posted Tuesday at 12:11 PM Share Posted Tuesday at 12:11 PM I recently had a very similar situation. I ended up measuring two circles. One near the top (-A-) and the other near the bottom of the 4.1355 cylinder and constructing my 3d line that way (Z Spatial). I ended up passing a type-1 GRR <20%. As far as the planar clocking goes. I don't see a tertiary datum? Could you simply translate by .1969 1 Link to comment Share on other sites More sharing options...
[Ow...] Posted Tuesday at 03:54 PM Author Share Posted Tuesday at 03:54 PM Please sign in to view this quote. Clark, What do you mean by translate by 0.1969? I hope to get time on the CMM this afternoon to double check a few things. Link to comment Share on other sites More sharing options...
[Cl...] Posted Tuesday at 03:56 PM Share Posted Tuesday at 03:56 PM Maybe I misunderstood that callout. With no tertiary datum. I'm not sure how I' clock it. 1 Link to comment Share on other sites More sharing options...
[Ri...] Posted Tuesday at 04:44 PM Share Posted Tuesday at 04:44 PM (edited) See that "Cross Hair"? According to ASME Y14.5, that is an implied 90°. Your offset is 90° from its shown dimension. The controls for datums A and B control the 90°. ASME Y14.5 2009 Please sign in to view this quote. Edited Tuesday at 04:53 PM 1 Link to comment Share on other sites More sharing options...
[Cl...] Posted Tuesday at 04:54 PM Share Posted Tuesday at 04:54 PM You need to clock something. Create a theoretical line through Ø -B-. Intersect that line with Ø -A- for a point (X+) Planar rotate about Z -5.44°. (If my math is right) using that intersected point. 1 Link to comment Share on other sites More sharing options...
[Ja...] Posted Tuesday at 07:42 PM Share Posted Tuesday at 07:42 PM Recall one of the circle paths of the eccentric bore cylinder to a circle feature and clock to that circle. Another way would be to create a secondary alignment using DATUM B for spatial, x and y origin. Use this secondary alignment to create a geometry best fit alignment for the eccentric bore cylinder and allow rotation around Z axis. Use this GBF alignment for location characteristics. 2 Link to comment Share on other sites More sharing options...
[Ow...] Posted Tuesday at 08:37 PM Author Share Posted Tuesday at 08:37 PM You all going to hate me, but I finally got back on it and..... the (*#&$@) part was moving :-(. I am using the line recalled between the intersections for planar. I do appreciate all of the replies and ideals. Link to comment Share on other sites More sharing options...
[Ri...] Posted Wednesday at 10:52 AM Share Posted Wednesday at 10:52 AM Don't hate the player, hate the game. 😄 1 Link to comment Share on other sites More sharing options...
