Get result_dimension on report from all stages
Hi,
i am looking for solution.
We would like to have a report page with 5 columns for 5 stages aka 5 measured parts, but i can not find a way to select dimension result for specific stage.
Is something like that possible? I mean, there should be a way because there is a trend view.
Thanks
Hi,
initialy this was posted in Inspect section.
We are measuring N of parts as first samples and we are using report style with dimension and tolerances on beginning of a row and then up to 5 columns for actuals.
I tried using stages to obtain such report, but i can not get actual from specific stage.
I know you how to get that from python but i didn't find how to place a python function into report column.
Any ideas?
Hello Martin,
"edit report" --> down left you can add columns or rows and you can also activate column or row per part/stage.
I would advice against it. Features like "ok nok" "position in tolerance zone" etc. do only work for one selected part if you use columns.
So if you export it you have to recreate those features by hand.
Better show every part in another row (for every dimension), that way exporting into excel for example is way easier.
Hi and thanks, but i have problems to obtain results from all stages on one page.
I know how to edit report and i think i can solve most of ongoing chalenges, but first i have to obtain results to be able to have one column per stage.
Similar thing what i would love to solve is combined measurement into one QDAS, but i don't need to use QDAS yet.
Yes, your posted image is what i would like to have, but i can not get results ( numbers in SN1_T1, T2, ... ) into the table.
I am not sure what i am doing wrong, i still get only active result.
Unfortunately, posted article didn't help. Those steps are done, but only one stage shown.
